View Full Version : LS1 fuel filter regulator
protour70
10-31-2005, 08:30 PM
Heres a pic of a finished 99 and up corvette regulator for a single LS1 fuel rail. Single line from tank to manifold as mentioned in previous posts. 1st time sending a pic. Thanks Mike
nitrovette
11-01-2005, 03:21 AM
im trying to decide if i want to do a single line or leave my feed and return setup from my tpi setup and just do the 98 fuel rails.Is there any advantage over the single line?
protour70
11-01-2005, 05:58 AM
The stock 2002 camaro fuel rail has a single inlet. The ricks hot rod shop's tank has a an-6 feed and return. My options were to change the fuel rail to a feed and return and run two lines or this set up and run one line. Not cheap either way.
badazz81z28
06-20-2012, 06:37 PM
Old post, but where did you put the regulator? Close to the rail or the tank?
Also Post $3 is confusing me. Why change the fuel rail?
