View Full Version : Looking for proven LS swap kit for Ridetech tru turn
CamaroJesse
12-25-2015, 03:12 PM
Im about to install an ls and t56 in to my 67 firebird with the ridetech tru turn. ive searched but cant seem to find a 100% proven combo. Does anyone know what works well?
thanks
Z06vet
12-25-2015, 03:16 PM
The newest holley swap parts work if youre willing to use their mid-length headers. I can say for sure that you can use the old hooker long tube swap headers, mast motorsports swap pan, stock size or smaller steering box (iroc box works as well), dirty dingo DD engine plates, short/wide frame stands and matching motor mounts. Scott
Toddoky
12-26-2015, 10:07 AM
Just to clarify, the entire new Hooker 1st-gen swap system of components can now be used with the Ridetech Tru-turn system, including the long-tube headers. The tube bend geometry of one of the tubes on the passenger side header was revised during the summer to eliminate the fitment interference issue that previously existed between the components. The older Hooker headers may fit with typical swap plates as well, but they don't provide the optimized drivetrain/ U-joint geometry that the new Hooker mounting components do, or allow installation of a T56 into the car without having to cut the floor. The new Hooker headers are also compatible with the stock, 3rd-gen IROC or Delphi 600 series steering boxes and provide much better spark plug/wire and ground clearance.
CamaroJesse
12-26-2015, 10:13 AM
So if i buy the complete Holley/hooker kit i should have no fitment issues? headers should clear the steering, oil pan will clear the frame, and trans should fit without cutting the tunnel? Also, how can i tell im getting the newest kit that will work with the tru turn.
thanks!
Toddoky
12-26-2015, 10:58 AM
The fitment of the Hooker components is what I was speaking of specifically. I've read user reports of having to modify the front corners of the Holley 302-2 pan sump to clear the inner tie rods on the Ridetech set-up on full-lock turns, but I cannot verify that on a first-hand basis. That leaves the Mast pan as an option for you if you want to keep things being a bolt-on operation. The revised design headers are easy to distinguish if you are buying them in stainless steel as they now are produced in our Bowling Green facility and carry a unique Hooker Blackheart line part number, which you will see when looking them up on the Holley website. The engine mounts and crossmember that you'll need to order are part numbers 12618HKR and 12626HKR respectively. Yes, the trans will fit without cutting the tunnel as long as you are using a stock subframe with stock height body bushings that are in good condition. There are multiple members here on this site that have used the whole Hooker set-up on their cars along with the Ridetech set-up that can report on the compatibility of everything for you first hand a tell you what oil pan they used...cwylie is one of those members, so you might want to send him a PM.
Z06vet
12-26-2015, 11:33 AM
Thats awesome you revised the headers to fit, I did not know that. I cant wait to try the new holley components on the next build.
Toddoky
12-26-2015, 01:01 PM
Yeah, I was happy to get that one taken care of...I modified enough sets for guys that it was easy to convince management that we should make the revision.
CamaroJesse
12-26-2015, 01:50 PM
Awesome! I will be ordering it all up this week. Thank you!!!
Rod
12-26-2015, 03:52 PM
what do you need to know? I have had an LS in my car for years, driven and raced
I used
Trans-dapt mounts...stock offset
Moroso LS Track Pan...with AN fittings for remote oil filter
Sandererson shorty headers..,allows for ground clearance and tru-turn
Holley accessory drive kit....with there PS pump and alternator
https://static1.pt-content.com/images/pt/2015/07/zzzzz_zpsbfx4pllv-1.jpg
Bad94
12-26-2015, 04:27 PM
72 Nova Ride Tech Level 3 with Tru Turn with LS7 dry sump pan. As far as I know this is the only car with the Tru Turn and LS7 oil pan.
AAM Solid Mounts
AAM Long tube headers
AAM Tranny cross member (T56)
NO cutting on the firewall or trans tunnel.
jlwdvm
12-27-2015, 06:58 AM
I used a complete kit...earlier version of the Hooker Long Tubes. I am using a Holley 302-2 pan with the baffle installed. I had to clearance a header tube on each side to clear the inner tie rod. I also had to grind down a inner corner on each side of the Tru Turn center link adapter to clear the oil pan at full lock. Nothing to extreme. I used the complete Holley-Hooker kit for my LS3-T56 swap into my 69 Firebird Track car build. Drive line angles were spot on and I didn't have to touch the firewall or floor pan. I have a Lee 600 steering box that has to be removed to get the drivers header on/off.
https://www.pro-touring.com/threads/102040-1969-Firebird-TA-clone-track-car-build
Motobrewmaster
12-27-2015, 07:10 AM
What is rubbing to cause the sparks in the picture?
I used
130fe
12-27-2015, 03:34 PM
I using Speed and Performance mounts, Autokraft oil pan, Speedtech trans crossmember and Stainless works headers. I am also using an AGR 12-1 steering box and complete Ridetech front and back (tru turn, SA coil overs and muscle bar). Everything fits without issue in the stock subframe. The headers are approx 1/2" below the subframe. No issues in 2500 street miles so far.
Rod
12-27-2015, 05:49 PM
the exhaust pipes rbbed coming off the rumble strips on the Las Vegas road course at OPTIMA
Motobrewmaster
12-30-2015, 05:20 AM
That must have been a bit unsettling!
paulk68
01-01-2016, 04:57 AM
This is great news! I am currently in the middle of this swap and the headers were a concern. So happy you fixed these to allow the use of long tubes.
CamaroJesse
01-01-2016, 12:39 PM
Im getting ready to order the holley engine mounts and trans crossmember however im trying to understand how the engine mounts work. do i use the factory engine stands that bolt to the frame? if so short/wide or tall/narrow? also do i need to order poly or rubber mounts or are these solid mounted? and which trans mount needs to be purchased? id guess turbo 400 mount?
thanks
Rod
01-01-2016, 12:49 PM
thanks
cant help didn't use any of that...
Rod
01-01-2016, 01:06 PM
didn't even notice....Trackside Suzy was my spotter and she notice the sparks ...that is at about 70+ mph and the car was under full compression coming out of a turn and off the rumble strips....tires didn't rub, springs and shocks didn't bottom out, so I pulled the front shocks off between sessions and added a medium afco bump stop to limit shocks compression length
rallystyle
01-01-2016, 01:11 PM
camarojesse
for your ls / t56 swap you need
pan 302-2 https://www.holley.com/products/ls_power/ls_swap_systems/1967-69_gm_f-body_ls_swap_components/parts/302-2
engine mounts https://www.holley.com/products/ls_power/ls_swap_systems/1967-69_gm_f-body_ls_swap_components/parts/12618HKR
trans cross member https://www.holley.com/products/ls_power/ls_swap_systems/1967-69_gm_f-body_ls_swap_components/parts/12626HKR
long tubes 1 7/8 https://www.holley.com/products/ls_power/ls_swap_systems/1967-69_gm_f-body_ls_swap_components/parts/70101308-RHKR
anchor 2292
prothane 7-1604-BL. if you want Polyurethane motor mount inserts you buy 7-1906-BL to get the trans mount and engine mount inserts.
it drops right in and fits good.
piratebaseball
02-28-2016, 08:07 PM
Has anybody used the Milodon 30915 oil pan with a tru turn steering set up? Just trying to confirm if this oil pan will work or not with the set up in a 67 camaro. Also, any negative things about the oil pan?
piratebaseball
03-02-2016, 08:41 AM
Hey Chris,
Which speed and performance mounts did you use? I'm assuming that is Texas Speed and Performance? I went to their website and looked and saw two different ones. Dirty Dingos and Hooker and they had a ton of different Dirty Dingos mounts. Also, do you attend any local car shows? I live in Brunswick, GA and am doing a lot of the same stuff you are doing with my 67 Camaro. I'd love to be able to see your car and how it turned out.
