View Full Version : ignition knock
cali-life
12-23-2015, 04:28 PM
Im in need of help bad can figure this out.
rewire my 68 Firebird front to back installed a few new parts to my 402 BBC new distributor msd street fighter i believe and new rebuild carb holley 650 double pumper.
After that when i started the car for the first time bad a really bad ingition dump knock from engine and back fire when revving high and it wont go away. only goes away when bass t timing is at around 55 deg ive heard thats to high. im trying to drive this car again but i dont want to block something up i also check for vacuum leaks did not find any
any help or someone run into something like this before?
andrewb70
12-23-2015, 06:54 PM
I would start over and make sure that the distributor is installed properly. You could easily be off a tooth or two...
dirty rick
12-24-2015, 07:44 AM
Balancer outer ring may have slipped.
55° is way too much
