View Full Version : Edelbrock Fuel Pump #1791 - 120GPH supports up to 480HP carb setup
jorgezee1
12-23-2015, 02:24 PM
Located CA 91792
Price:160.00 obo
Edelbrock Fuel Pump 1791 - 120GPH supports up to 480HP carb setup.
#1791 is factory preset to 6.5 psi and no regulator is required.
Used low mile fuel pump. It's just sitting in the garage now. I will get pics and more information on the pump tonight. Feel free to ask any questions.
https://www.pro-touring.com/threads/109220-Edelbrock-Quiet-flow-fuel-pump-model-1791?highlight=edelbrock+1791
Comes with AN fittings and mounting hardware.
https://static1.pt-content.com/images/pt/2015/12/IMG_4286-1.jpg (http://s689.photobucket.com/user/jorgezee1/media/Camaro/IMG_4286.jpg.html)
I bought this from another member. Never installed or used it. I decided to go from Carb to EFI on my Falcon.
http://www.edelbrock.com/automotive/mc/fuel-pumps/
QUIET-FLO™ ELECTRIC FUEL PUMPS (CARB)
These state-of-the-art electric fuel pumps offer maximum performance in a compact package. With anodized aluminum housings and high-quality internals, they are both strong and durable. Each pump is factory-tested and includes mounting brackets. The carbon vanes and composite rotor give these pumps the added boost for maximum performance. The high quality construction results in a pump that is 4 to 14 dB quieter than competitors' pumps at the same pressure. #1791 is factory preset to 6.5 psi and no regulator is required. With a replaceable screen type inlet filter and the free flow rate of 120 GPH it is sufficient to supply 480 hp.
jorgezee1
12-29-2015, 11:01 AM
Open to offers or trades.
69 Camaro
Ls swap parts
Injectors
Fuel lines
or
63 falcon Parts
Ford 302 5.0 Fuel injectors
Fuel Lines
or
Tools
Brake or Fuel specialty tools
Torque wrench - calibrated
