PhillipM
12-23-2015, 08:27 AM
Here's what I've got going on. AC Delco 18M974 Master and a Tuff Stuff 2229NB Booster. When I started bleeding I had the res full and the cap on tight. Everything went fine for a bit and started to build a pedal then all of the sudden, nothing. Bunch more air in the lines and no amount of bleeding would do anything. I decided to check the master. Take the cap off and put some more fluid in it. Put the cap back on and boom, start getting a pedal again. Then... nothing. I went through this a couple of times before realizing, it was the cap on and off that was making changes. When I leave the cap off or just loosely set on top of the master it bleeds just fine. If I tighten the cap then it's like it starts to get a vacuum and sucks air in from somewhere else. Has anyone been through this? Is the vent in the cap bad? Thoughts?
https://static1.pt-content.com/images/pt/2015/12/IMG_5574_zpslhq7miqb-1.jpg (http://s43.photobucket.com/user/pmckee/media/F85/IMG_5574_zpslhq7miqb.jpg.html)
