Rich G
12-20-2015, 08:16 AM
Hey guys, I found a 2006 GTO for parts and was wondering if the front and rear brakes can be installed onto my 67 Camaro with disc fronts and 12 bolt rear with drums? I have done a little research and if I understand this right these are c5 brake components. Can I use the master cylinder setup and proportioning valve as well from GTO? It looks like Kore3 might be the place to call for brackets and brake lines, so since my 67 has disc brake spindles on it I will need to switch to a drum spindle and hub assembly, is this right? I am running a big block Chevy with tall valve covers, if the master cylinder from the GTO will work will it clear the valve covers or is it to large? I can buy the calipers and rotors for $350. Is that a fair price and is that all that is needed or will I need brackets from GTO too? Any help or info will be appreciated Rich
