View Full Version : LS7 Short Block, Heads, Intake, Coils and More
quarterbooty
12-19-2015, 07:16 PM
LS7 Lifters
Used set of LS7 lifters that were in the short block described above. They appear to be in good working order. Price is $40 for the set plus shipping from 66206.
https://static1.pt-content.com/images/pt/2015/12/IMG_0116-1.jpg
https://static1.pt-content.com/images/pt/2015/12/IMG_0117-1.jpg
Texas Speed Pushrods
Texas Speed 3/8” diameter pushrods with a length of 7.750”. These are in excellent condition. Price is $100 for the set plus shipping from 66206.
https://static1.pt-content.com/images/pt/2015/12/IMG_0122-1.jpg
quarterbooty
12-21-2015, 07:14 AM
Plug wires are sold. Let me know if you have any questions on the other items.
Jdseeling
12-21-2015, 05:07 PM
I would like to chat with you more about the short block and heads. What is a good time tomorrow? Shoot me a PM. David
quarterbooty
01-04-2016, 06:13 AM
Bump.
badazz81z28
01-04-2016, 04:51 PM
Did you actually replace the head gaskets and it was still leaking? Was there actually coolant in the oil or just condensation sludge on the cap?
parsonsj
01-04-2016, 05:54 PM
Plug wires are sold.And exactly as advertised. Thanks Nick!
quarterbooty
01-04-2016, 07:29 PM
After noticing coolant loss, I pressure tested the coolant system. When it failed to hold pressure, I pulled the heads with the motor still in the car. The mating surfaces and head gaskets looked fine (GM MLS), but I replaced them anyway in hopes of a simple solution. I changed the oil and filter, and you could tell it was contaminated with coolant (the oil had a green tinge to it). I cut the oil filter open, and there were no signs of bearing material in the filter element. After reassembly, I took it back out for a couple test drives and some coolant loss was subsequently observed. I pressure tested the coolant system again, and it failed to maintain pressure (no difference in behavior from the prior tests). As a last ditch check, I bought a Uview combustion leak tester. No combustion gas was detected in the coolant system, which ruled out a failed head gasket. This was the extent of my failure investigation. As indicated in the original post, there are no visible cracks in any of the sleeves (at least the accessible sections). Let me know if you have anymore questions. Thanks.
would you sell is as a bare block please email me
Joe
CorvetteMick
02-20-2016, 07:20 AM
How many miles on the coils?
Mick
quarterbooty
02-20-2016, 03:07 PM
Everything has sold except the lifters and the pushrods. I had this stuff listed locally as well and forgot to update this ad. My apologies for the confusion.
