View Full Version : Ford 9" Housing with Drum Brakes
j455cb
12-16-2015, 11:16 AM
I have a ford 9" housing set up that I bought for my 1970 Buick GS455 I was able to get it bolted in but found out it was too narrow. The rear should bolt up to a G-body with little or no modification. The rear end housing is 58" wide measuring wheel mount to wheel mount which is the correct width for a G-body. The housing measures 53" wide from flange to flange which is also correct for a G-body. The axles are what I believe currie as is the housing. The axles have new bearings and seals installed in the housing. Southside Machine Performance sells adjustable upper control arm to bolt the rear housing into a G-body or weld on new upper mounts. The housing has been powder coated gloss black. I would like to get $500 for the housing which I think is fair.
https://www.pro-touring.com/attachment.php?attachmentid=121038&stc=1
Impala67
12-16-2015, 11:51 AM
Interested. PM Sent
MOREHORSEPOWER
12-16-2015, 07:02 PM
Location ?
j455cb
12-16-2015, 07:50 PM
Nashville TN
j455cb
01-13-2016, 08:58 AM
i have a ford 9" housing set up that i bought for my 1970 buick gs455 i was able to get it bolted in but found out it was too narrow. The rear should bolt up to a g-body with little or no modification. The rear end housing is 58" wide measuring wheel mount to wheel mount which is the correct width for a g-body. The housing measures 53" wide from flange to flange which is also correct for a g-body. The axles are what i believe currie as is the housing. The axles have new bearings and seals installed in the housing. Southside machine performance sells adjustable upper control arm to bolt the rear housing into a g-body or weld on new upper mounts. The housing has been powder coated gloss black. I would like to get $500 for the housing which i think is fair.
sold
