View Full Version : Pinion Angle
Pompel
12-06-2015, 08:15 PM
I have a problem connecting the two u-joint's on my Unisteer rack and pinion due to the headders (SBC connecting kit).
How will a 3/8" lift on the motor affect the pinion angle?
Z06vet
12-20-2015, 08:57 AM
It will def affect it. Might not cause a problem, depending on your existing angles. I'd shim the trans tailshaft the same amount, that should leave you right where you started in regards to engine/trans angle.
Motorcitydak
12-20-2015, 10:35 AM
If your engine and trans mounts are 3 feet apart (I'm just guessing, I dunno what your spacing between them is), you will change the angle of your output 0.6 degrees
