View Full Version : t56 pilot bearing
thumper877
12-01-2015, 04:53 PM
I have a new crate motor ls3 525 hp I just got my t56 magnum close ratio 6 speed do I need to change the pilot bearing or will the factory one work thanks
Oregon
12-01-2015, 06:36 PM
There are two different pilot bearings. One is larger outer diameter and sits closer to the transmission. The other is smaller and sits deeper in the crank.
http://www.lateral-g.net/tech_articles/LS7_install/0019.jpg
The way I checked was to install the bell-housing (and block saver plate) on the transmission and measure the length of the input shaft extending beyond the bell-housing.
From the GM performance parts catalog:
14061685 Pilot Bearing (not shown) Use with manual transmissions if the input shaft extends beyond the bell housing more than 20mm
12557583 Pilot Bearing (not shown) Use with manual transmissions if the input shaft extends beyond the bell housing 5mm or less (or recessed slightly)
icemanrd19
12-01-2015, 07:01 PM
shouldn't have a pilot bearing installed. I have a extra one. I didn't know there was two options. pace performance sent me mine
thumper877
12-01-2015, 07:05 PM
Thanks great info Oregon appreciate it
badazz81z28
12-01-2015, 08:10 PM
It's the bellhousing that dictates the bearing. What bellhousing are you using?
thumper877
12-02-2015, 05:30 AM
The quicktime steel housing
badazz81z28
12-03-2015, 06:04 PM
The smaller bearing is the correct one.
thumper877
12-04-2015, 04:06 AM
Thank u
