View Full Version : 1969 Camaro Wheel fitment
Pompel
11-30-2015, 10:27 AM
I need some help from you professionals out there.
Will a 17" 7" wide with 4" backspacing fit on -69 Camaro with original subframe without subbing?
235 wide tires. Ridetech A-arms and spindle!
Rear 18" 8" wide with 4" backspacing stock rear.
Gil
12-02-2015, 07:10 AM
Hi Pompel
For what I can say 69 Firebird stock SF, I run 17x8 w/ 4.5 BS & 235 tires all 4 corners without rubbing issues
I think your front setup is fine & you can go wider too in the rear like 18x 9/9.5 with 5/5.5 BS & 265/275 tires!
120270
Gil
camarodude87
12-02-2015, 07:26 AM
Gil, Great looking wheel and tire set up. Looks awesome.
Gil
12-02-2015, 10:59 AM
Thank you !
67rally
12-02-2015, 12:56 PM
235 is a lot of tire to put on a 17x7 wheel.
Ideally you would want 4.25" bs on a 7" wheel to center it in the wheel well. 4" bs will push it out 1/4" more, which should be fine with a 235.
Pompel
12-02-2015, 02:46 PM
Thanx for all the information. Found this tool http://www.willtheyfit.com/
