Ron Sutton
11-23-2015, 06:47 PM
The Ultimate Holiday Promotion for
The Ultimate Pro-Touring Front Suspension!
Speedtech Front Clips & Full Frames
Holiday Promotion ONLY THROUGH Saturday, December 19th
ONLY 5 DAYS LEFT
You Can Have It All ...
Get Ron Sutton Optimized Geometry ... Designed In
Get Ron Sutton Optimized Suspension Set-up ... Tailored for YOUR Car
And ... Ron Sutton Secret Sauce Shocks ... For Ultimate Grip
At NO EXTRA COST
Plus Free Crating
What the heck? It's Simple.
Buy any Speedtech ExtReme Front Frame & Suspension ... or Full Frame & Suspension ... from RSRT & Get:
1. Ron's Tech Service #40STP ($200) to Optimize YOUR Car's handling & have Ron Create a BALANCED Set-up for YOUR CAR - Included at No Charge
2. All of your Ridetech coil over shocks upgraded with Ron Sutton Secret Sauce Valving & Special Digressive Pistons - Included at No Charge
3. The Crating Charge ($200) Covered by Ron
New Speedtech Front Subframe & Suspension Package
New Cutting Edge Design Includes:
Strong Box type laser cut and jig welded construction - reduced weight over factory subframe.
Special subframe width & shape allowing 315 front tires.
Factory alignment holes offer ease of aligning frame to body and bumpers.
Mounting hardware, instructions, and custom alignment specs.
Ron Sutton Race Technology geometry built-in.
Upper control arms feature additional caster adjustability.
Speedtech high clearance upper & lower tubular control arms
Control arms powder coated gloss black and fully assembled with Delrin bushings.
3-piece Speedway Engineering sway bar – Wide choice of rates.
Unisteer power rack & pinion steering.
Next-Gen ATS 7075 Forged Aluminum Spindles.
ATS high-Ackerman steering arms for ATS spindles.
C7 heavy duty bearings & hubs.
Increased header and exhaust clearance.
Motor stands accept small block engines with OEM style mounts.
Accepts LSX engines with Speedtech fabricated oil pan and motor mounts.
Adjustable engine frame stands allows 3/4" fore & aft range.
Fully adjustable rear cross member fits all GM transmissions as well as T-56 and TKO.
Built-in tow/tie down hooks eliminate strapping around painted frames.
Comes bare. Powder coat options available.
119958
Available as Bolt-In Clips for:
67-69 GM F-Bodies Camaros & Firebirds
70-81 GM F-Bodies Camaros & Firebirds/Trans Ams
68-74 GM X-Bodies Novas, Venturas, Skylark & others
From Ron Sutton Race Technology, the base Front Clip Package includes:
Ridetech single adjustable mono-tube gas coil-over shocks, including delrin thrust washers & adjusting wrench.
Hypercoil coil-over springs – Wide choice of rates.
Base Price is $7099 + $200 crating fee
OPTIONS:
• Powder Coat Subframe – Flat Black
• Powder Coat Subframe – Semi-Gloss Black
• Powder Coat Subframe – Gloss Black
• Powder Coat Subframe – Gun Metal Grey
• Powder Coat Subframe – Silver
• Billet Aluminum Body Mount Set
• Engine Bay Round Tube Chassis Down Bar Supports
• Double Joint Steering Shaft Kit
• LSx Engine Adapter Plates
• Speedtech 1 3/4" LSx Headers, Mill Finish
• Speedtech LSx 1 3/4" Headers, Show Polished Finish
• Speedtech 2" LSx Headers, Mill finish
• Ron Sutton Tailored Suspension Tech Service #40STP
• Ron Sutton Tailored Brake Tech Service #29
• Ridetech Digressive Single Adj Shocks w/AutoX-Star Valving
• Ridetech Digressive Triple Adj Shocks w/AutoX-Star Valving
• JRI Digressive Triple Adj Shocks w/AutoX-Star Valving or Track-Star Valving
So You Get ...
* The latest design in front suspension & steering
* A Balanced Suspension Package Tailored to You
* Secret Sauce, Digressive, High Grip Shock Valving
* Save $800
For more information ... OR To Place Your Order ... Contact Ron Sutton Race Technology:
Phone: (916) 834-8051
Email: [email protected]
Address: 11374 Amalgam Way, Suite K, Gold River, CA 95670
Website: www.RonSuttonRaceTechnology.com (http://www.RonSuttonRaceTechnology.com)
ONLY 5 DAYS LEFT
At NO EXTRA COST
Plus Free Crating
119958
OPTIONS:
So You Get ...
* Save $800
