View Full Version : 67 camaro door glass
paint2361
11-22-2015, 07:52 AM
Whats the trick to installing a new track/channel/roller seal assy to a new window glass? It has a rubber seal that goes into the glass channel. It seems way too tight....
thumper877
11-22-2015, 08:10 AM
There is a tool for doing this it fits over the channel and u hammer on the tool not the channel I'm sure u could take it to a glass shop and let them do it it shouldn't be but a few dollars and if u do it wrong u have a broken glass
minendrews68
11-23-2015, 04:47 PM
It's really not that hard to do. It is hard to get into the channel with the rubber so it seals and doesn't come back out. Make sure you have the right thickness of rubber, or you'll never get it in. Although it sounds creepy I used the equivalent of KY jelly to install mine. It is water based so it will evaporate completely after assembly. Sure makes things go together a lot easier.
Z06vet
11-29-2015, 05:27 AM
I used dish soap on the last set I did. I flipped the glass so the bottom was up, and set the top on few layers of cardboard. Took my time & used rubber mallet to work the channel over the glass. I found some to be easier than others. New glass and new rubber channel can be quite difficult.
icemanrd19
11-29-2015, 07:00 AM
Yes dish soap and water. Works well
