View Full Version : LSA Valve Covers
Simbad68
11-03-2015, 03:49 PM
Looking for a set of LSA valve covers. Thanks- Sims
Schwartz Performance
11-03-2015, 04:48 PM
We have some, no miles. Make an offer, PM me
-Dale
Samckitt
11-04-2015, 05:03 AM
Are LSA valve covers different?
11-04-2015, 07:56 AM
The LSA and 9 have no coil brackets. They also look different without the coils on.
-Dale
Vegas 69
11-04-2015, 08:10 AM
-Dale
They also have more room for higher lift cams
Simbad68
11-04-2015, 08:15 AM
-Dale
PM Sent!
Simbad68
11-04-2015, 08:19 AM
LS3 coil bracket's also set several of the coils up against the fuel rails. Pinching the wires.
Simbad68
11-04-2015, 09:28 AM
For clarity, I'm running a ZL1 supercharger. This is where the fuel rail issue is with the LS N/A valve covers.
Samckitt
11-04-2015, 10:40 AM
Hmmm..... I have the CTS-V supercharger to install some day on my LS2 (LS3 heads), so it wont fit with the stock LS2 valve covers/coils?
130fe
11-04-2015, 01:43 PM
The LSA valve covers have the coil mount bosses built in to them. I was running them before I swapped to the Holley ones. Take a look at this post, don't know if it will help your issue (post 265)- http://ls1tech.com/forums/conversions-hybrids/1456840-66-impala-convert-ls2-conversion-14.html The Holley ones might give you the clearance you need. Be advised that the LSA covers have a oil cap that locks in (normally not removed). I had removed that cap and just screwed in the factory oil cap and filler neck and it worked fine.
Simbad68
11-04-2015, 04:06 PM
I had 2 coil connectors that were binding up on the fuel rail. My concern was the wires coming out of the connects would be damaged and short out on the fuel rail.
