67 455 Bird ragtop
10-19-2015, 05:54 AM
I'm in the process of wiring up my gauges and dash cluster. I will be using all Auto Meter gauges and a Covan dash. So I'll need to install/connect all my indicators and gauges. I do plan to retain the "idiot light" functionality to supplement my gauges. My car is a 67 'Bird. I want to make sure I under stand how each of the 9 leads in the connector that normally attaches to the gauge cluster works. If I have anything wrong please correct me.
Pin 6 - This supplies power to the gauge cluster. I should be able to pull power for my gauges and "idiot lights" from here.
Pins 2,3,5, & 8 are all leads from sensors/switches. My understanding is these are ground leads that are grounded when the switch or sensor closes the circuit.
Pins 1 & 4 are the turn signal leads. These are powered leads so any bulbs/leds will need to be grounded like any other light. The flasher unit supplies the power through these leads.
Pin 7 supplies the resistance/reading from the sensor in the fuel cell. This feed needs to be connected to the proper connection on my fuel level gauge.
Pin 9 - This controls the power to any gauge lights for night driving. It also controls the dimming function from the headlight switch.
Does this sound correct ??
Thanks for any feedback.
Here's a link to a schematic to the stock dash harness.
http://thefirstgensite.com/library/electrical/67wir/67wir1.html
