408maro
10-18-2015, 07:40 PM
Thanks everyone for helping me out in my AAW questions that I had for my 72 camaro . It's been a long and learning process and one that makes me hate electrical even more..
I got most the AAW wiring done and it's time to get the Dakota digital installed.
AAW suggest that I wire the VSS sensor to the wires that come out from the engine bay bulkhead connector and then wire from the dash kit portion to the Dakota box, now can't I just eliminate that hoke process and wire it directly from the sensor to the box?
Am I supposed to splice into the Custer connector to get the connections I need to the Dakota box such as fuel. Headlights. Turn signals and tach?
If that's so I haven't got that far in my AAW kit it's just the harness off the fuse block waiting to be put together. Should I just bypass making the factory cluster connector and wire directly to the Dakota box as well.
Or should I hook everything up as if I was going to use a factory cluster and splice into it?
John
John
