View Full Version : 1978 Mustang II restomod
rusty428cj
10-14-2015, 08:55 AM
I took this in trade a few years ago toward some of the labor on restoring a Mustang. This is what we are starting with. The hood scoop has to go. I have always liked the Mustang II and I plan on making this my driver.
https://static1.pt-content.com/images/pt/2015/10/02-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/02.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/05-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/05.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/06-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/06.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/10-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/10.jpg.html)
rusty428cj
10-14-2015, 09:04 AM
I'm not sure what they were thinking or what they used to cut this hole in the hood.
https://static1.pt-content.com/images/pt/2015/10/DSCN8102_zpsdadf80e1-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8102_zpsdadf80e1.jpg.html)
After Brian worked on it
https://static1.pt-content.com/images/pt/2015/10/DSCN8127_zpsf702c157-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8127_zpsf702c157.jpg.html)
The hood was sanded down to bare metal and all the old scoop holes welded.
https://static1.pt-content.com/images/pt/2015/10/DSCN8141_zps409081d6-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8141_zps409081d6.jpg.html)
It looked good before it was primed but it needs a lot of work
https://static1.pt-content.com/images/pt/2015/10/DSCN8144_zps4ca72bfa-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8144_zps4ca72bfa.jpg.html)
After a little block sanding and bodywork
https://static1.pt-content.com/images/pt/2015/10/DSCN8168_zpsb212d07e-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8168_zpsb212d07e.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/DSCN8172_zps471767a8-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8172_zps471767a8.jpg.html)
I plan on using the Mach 1 scoop and once that comes in I will bolt it on and finish the bodywork. At this time the hood is low in front of the hole but the scoop should draw that up.
I sprayed a couple of coats of epoxy to seal the bodywork.
https://static1.pt-content.com/images/pt/2015/10/DSCN8257_zpsca37a452-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8257_zpsca37a452.jpg.html)
A had enough Slick Sand polyester primer for a couple of coats
https://static1.pt-content.com/images/pt/2015/10/DSCN8356_zps6e2c5abd-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8356_zps6e2c5abd.jpg.html)
Block sanded with 80 and found one low spot that required a little filler
https://static1.pt-content.com/images/pt/2015/10/DSCN8386_zps5646860a-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8386_zps5646860a.jpg.html)
Two coats of SPI Turbo primer
https://static1.pt-content.com/images/pt/2015/10/DSCN8387_zps8d22db7c-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8387_zps8d22db7c.jpg.html)
The hood required a lot of work but I'm happy with it now.
https://static1.pt-content.com/images/pt/2015/10/DSCN8395_zps5f1f42aa-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8395_zps5f1f42aa.jpg.html)
rusty428cj
10-14-2015, 09:08 AM
We have a new problem. This was filled with bondo. I had not planned on taking out the gas tank.
https://static1.pt-content.com/images/pt/2015/10/DSCN8288_zps430c14b0-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8288_zps430c14b0.jpg.html)
The rust was cut out.
https://static1.pt-content.com/images/pt/2015/10/DSCN9440_zps1cabc458-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN9440_zps1cabc458.jpg.html)
Eleanor gas filler kit from Mustangs to Fear was welded in place. A gas filler neck from a 1968 Mustang was also used.
https://static1.pt-content.com/images/pt/2015/10/DSCN9448_zpsc6392dff-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN9448_zpsc6392dff.jpg.html)
Billet gas cap from Mustangs Unlimited
https://static1.pt-content.com/images/pt/2015/10/DSCN9446_zps74f63176-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN9446_zps74f63176.jpg.html)
rusty428cj
10-14-2015, 09:12 AM
I wanted a cleaner looking taillight panel so the Ford holes were welded and ground down
https://static1.pt-content.com/images/pt/2015/10/DSCN9434_zpsa346e7d2-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN9434_zpsa346e7d2.jpg.html)
The bodywork is finished on the taillight panel
https://static1.pt-content.com/images/pt/2015/10/DSCN9558_zps12f2f5d2-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN9558_zps12f2f5d2.jpg.html)
Scottrods rear bumper fits great. The original bumper brackets were cut off and two holes were drilled in the trunk for a test fit. Add a few more bolts inside the trunk and a couple on each quarter and your done.
https://static1.pt-content.com/images/pt/2015/10/DSCN9588_zpsc13cc7bc-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN9588_zpsc13cc7bc.jpg.html)
cbpldc
10-14-2015, 10:36 AM
Awesome! Thank you for putting this up!
Chris
cbpldc
10-14-2015, 10:38 AM
I see its a T-top car and has some Fox 4 lug ponies on it. What are your plans for the powertrain? Going to stay with the C4? 4R70W swap or Aod?
Going carbed or Fuel injected? I love these cars. My friend had a King Cobra with the mesh wheels, 302 and a 4 speed, and it was one of the first cars I rode in that truly scared me from a power / flimsy chassis ratio. I've loved them since then!
Chris
Alwhite00
10-14-2015, 11:26 AM
Looking good - Keep the pictures coming.
rusty428cj
10-14-2015, 11:34 AM
We found a 8" rear from a 1965 Mustang. The spring perches are a little wider on the rear but we made it fit. I ordered a 1" lowering kit.
https://static1.pt-content.com/images/pt/2015/10/DSCN0166_zpsc13b33c8-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0166_zpsc13b33c8.jpg.html)
I installed a Rod & Custom front suspension in my 1968 Coupe and upgraded to Baer brakes so I used the original ones that came with the kit on the II.
https://static1.pt-content.com/images/pt/2015/10/DSCN0174_zpsacce4628-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0174_zpsacce4628.jpg.html)
The front fiberglass bumper was to wide and shaped wrong at the bottom
https://static1.pt-content.com/images/pt/2015/10/DSCN0278_zps37097cf2-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0278_zps37097cf2.jpg.html)
I cut and taped a piece of aluminum
https://static1.pt-content.com/images/pt/2015/10/DSCN0279_zps969b79d9-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0279_zps969b79d9.jpg.html)
Added three layers of fiberglass mat
https://static1.pt-content.com/images/pt/2015/10/DSCN0286_zps7a8515ac-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0286_zps7a8515ac.jpg.html)
Removed the aluminum
https://static1.pt-content.com/images/pt/2015/10/DSCN0288_zpsd0ebce8a-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0288_zpsd0ebce8a.jpg.html)
Still needs more work
https://static1.pt-content.com/images/pt/2015/10/DSCN0298_zpscd68a2f1-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0298_zpscd68a2f1.jpg.html)
When I'm finished the valance and bumper will be one piece.
https://static1.pt-content.com/images/pt/2015/10/DSCN0336_zps3fb08af5-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0336_zps3fb08af5.jpg.html)
I added 3 layers of fiberglass mat on each end and now all I have to do is fit the center piece and a lot of bodywork and I will have a one piece bumper and valance!!
https://static1.pt-content.com/images/pt/2015/10/DSCN0340_zpsaa6d5b81-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0340_zpsaa6d5b81.jpg.html)
Test fitting the one piece bumper and valance
https://static1.pt-content.com/images/pt/2015/10/DSCN0403_zpshzr1bw3h-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN0405_zpsappvvpt9-1.jpg
I still have a little work to do to get it lined up to the fenders
https://static1.pt-content.com/images/pt/2015/10/DSCN0406_zps3uzli8st-1.jpg
I_make_oil
10-14-2015, 05:21 PM
Cool project. Nice to see you building a daily driver like this. Subscribed.
windows
10-14-2015, 05:47 PM
Cool. Great quality. Going to be nice.
69stang
10-15-2015, 08:10 AM
Rusty, excellent project. I've been wanting to build a DD mustang II for several years now. Been looking for a good running 302 non T-top hatchback car. Had a 78 T-top car in the early 90s, didn't care for the T-tops. Want to go with a mild carbed 302 with 5-speed. Passed on a couple of cars so far this year, neither was currently drive-able. I'll be watching this one.
twosaturns
10-15-2015, 01:44 PM
you're managing to make a II look pretty good, nice job!
my Dad had a '78 Mustang V6/4 speed, for a little while back in the day; bright metallic blue, white vinyl roof notchback, white vinyl interior with a blue rug. hideous. all that and terrible handling too!
Ben@SpeedTech
10-15-2015, 02:59 PM
I was getting all excited and then the thread ended. More!!!
Godbolt
10-15-2015, 05:21 PM
Great job on the bumper and front valance. The original monstrosity ruined the entire front end of the car. Yours looks right!
rusty428cj
10-16-2015, 05:57 AM
I don't like the T-tops but I'm stuck with them. This was somewhat of a driver when I got it but after sitting for a couple of years it didn't want to start.
rusty428cj
10-16-2015, 06:15 AM
We had a few rust holes in the floor that were cut out and new metal added.
https://static1.pt-content.com/images/pt/2015/10/DSCN0260_zpsfecdcbdf-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0260_zpsfecdcbdf.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/DSCN0264_zpscaac976c-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0264_zpscaac976c.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/DSCN0293_zps608fcbf6-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0293_zps608fcbf6.jpg.html)
Floor was sanded and epoxy primed black
https://static1.pt-content.com/images/pt/2015/10/DSCN0309_zps7cffd224-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0309_zps7cffd224.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/DSCN0310_zpse970c869-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0310_zpse970c869.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/DSCN0313_zps45705e1c-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0313_zps45705e1c.jpg.html)
Because this has a T-top we are going to add subframe connectors and a roll bar from S&W. The roll bar was sanded and epoxy primed.
https://static1.pt-content.com/images/pt/2015/10/DSCN0337_zpsf13dd987-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0337_zpsf13dd987.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/DSCN0338_zpsa55fbf1f-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN0338_zpsa55fbf1f.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/DSCN0649_zpsoh5un7bl-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN0661_zpsio6qfvna-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN0665_zpsshetz1zq-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN0667_zpsar2q6bwr-1.jpg
rusty428cj
10-16-2015, 06:27 AM
The major bodywork is finished
https://static1.pt-content.com/images/pt/2015/10/DSCN0670_zpshnemds2r-1.jpg
Two coats of SPI epoxy
https://static1.pt-content.com/images/pt/2015/10/DSCN0676_zpso116qlrc-1.jpg
Block sanded and a little more bodywork
https://static1.pt-content.com/images/pt/2015/10/DSCN0681_zpscbcvfh9p-1.jpg
More epoxy
https://static1.pt-content.com/images/pt/2015/10/DSCN0686_zps6bgax5en-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN0831_zpsth8b9yvj-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN0833_zpskkujl1e8-1.jpg
I block sanded again and sprayed white epoxy. I have decided on a color SPI Orange. It is a little darker in person
https://static1.pt-content.com/images/pt/2015/10/DSCN0931_zpsbez77si9-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN0933_zpscmpymy3m-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN0929_zpsszevse4i-1.jpg
cbpldc
10-16-2015, 06:35 AM
Yes! I also spy 5 lug wheels!
rusty428cj
10-16-2015, 09:37 AM
The fenders have been sprayed white epoxy almost ready for SPI orange paint then I decided to fill in the marker lights
https://static1.pt-content.com/images/pt/2015/10/DSCN8534_zps99de6e4b-1.jpg (http://smg.photobucket.com/user/rusty428cj/media/1978%20Mustang%20II/DSCN8534_zps99de6e4b.jpg.html)
Ready for more primer. The wheels are off of Brian's 94 but the offset is wrong and the front cap won't go over the spindle
https://static1.pt-content.com/images/pt/2015/10/DSCN0853_zpsgyhjjbnf-1.jpg
I sprayed two coats of SPI epoxy primer on the body and roll bar
https://static1.pt-content.com/images/pt/2015/10/DSCN0946_zps3vjcqe2l-1.jpg
I finished the bodywork and sprayed a coat of epoxy to seal it before spraying urethane primer
https://static1.pt-content.com/images/pt/2015/10/DSCN1024_zps7kicilmu-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1026_zpsgwu0gvc9-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1027_zpsj9ifkqap-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1028_zpseupasqqj-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1030_zpslropjfx2-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1031_zpsw0gv7nzi-1.jpg
The body has been block sanded and I sprayed a couple more coats of SPI Turbo urethane primer.
https://static1.pt-content.com/images/pt/2015/10/DSCN1066_zpswsxacakv-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1067_zpse52iyzec-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1070_zpsyxkq9j1r-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1071_zpshv19jmqi-1.jpg
rusty428cj
10-16-2015, 09:45 AM
The wheels and tires are will be using
https://static1.pt-content.com/images/pt/2015/10/DSCN1522_zpsyspkw5ur-1.jpg
Dave B
10-16-2015, 07:06 PM
Looking pretty sweet!
alcino
10-16-2015, 10:25 PM
Looking awesome! My car is in need of some body work and paint(again). Your posts are motivating me to get some progress going. Loving your bumper and other body mods. Hope you don't mind me using some of them on mine. Keep your detailed updates coming.
wfo guy
10-17-2015, 04:52 AM
Looking good so far!
rusty428cj
10-17-2015, 05:09 AM
I don't mind. That front bumper/valance was a lot of work. I was going to add a spoiler but after cutting and mocking it up I didn't like how it looked.
rusty428cj
11-07-2015, 10:41 AM
I decided it was time to upgrade the engine compartment
https://static1.pt-content.com/images/pt/2015/11/DSCN1729_zps88fmyrxv-1.jpg
https://static1.pt-content.com/images/pt/2015/11/DSCN1779_zpskle3pcpr-1.jpg
Two coats of SPI black epoxy
https://static1.pt-content.com/images/pt/2015/11/DSCN1909_zpsjamlf9kg-1.jpg
The spring perches on the 1965 rear end are 1/4" to wide on each side so we added metal to the bottom of the perch with an offset hole.
https://static1.pt-content.com/images/pt/2015/11/DSCN2126_zpsmpwulwwe-1.jpg
New rear shackles and test fitting the rear after the leaf springs were sanded and epoxy primed.
https://static1.pt-content.com/images/pt/2015/11/DSCN2198_zpspg4ynro4-1.jpg
It is hard to believe but new motor mounts for a V8 are not available so we made our own. We had a set Rod & Custom small block motor mounts that we did not use on another project. They were cut down and welded to the frame
https://static1.pt-content.com/images/pt/2015/11/DSCN2177_zpsuhmuvelr-1.jpg
We will add another brace after the firewall is modified for the AOD and we install the engine and trans again
https://static1.pt-content.com/images/pt/2015/11/DSCN2189_zpsqfz5lrfn-1.jpg
DrFraZZy
12-01-2015, 05:32 AM
Any updates? It has been nearly a month
rusty428cj
12-01-2015, 06:24 AM
I ordered a spoiler from Mustangs Unlimited but after test fitting I realized I never did like how the spoiler is on the quarter panel and how tall it was.
https://static1.pt-content.com/images/pt/2015/12/DSCN1107_zpsde04boom-1.jpg
I cut it down and added a little fiberglass
https://static1.pt-content.com/images/pt/2015/12/DSCN1669_zpskeiqxosn-1.jpg
After some bodywork
https://static1.pt-content.com/images/pt/2015/12/DSCN1681_zpsubqctw7p-1.jpg
Epoxy primed
https://static1.pt-content.com/images/pt/2015/12/DSCN1714_zpst4allurx-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN1747_zpskpl5kt4q-1.jpg
We had to do a little rust repair to the hatch and bodywork and I painted the back side SPI Orange. The spoiler was bolted and fiberglass mat was added and needed bodywork before the back was painted.
https://static1.pt-content.com/images/pt/2015/12/DSCN2142_zpsaqoo67f4-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2320_zpst3un3vom-1.jpg
rusty428cj
12-01-2015, 06:31 AM
I painted a few more parts
https://static1.pt-content.com/images/pt/2015/12/DSCN0989_zpsp1yrhw65-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN0990_zpsjgtueiek-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN0992_zpspdyrz2ji-1.jpg
DrFraZZy
12-01-2015, 06:37 AM
The updates, I was looking for!!! Wow, the color reallllllyyyy pops! The spoiler modification might not be noticed down the road without pointing it out and shortening it up really cleans up with the body lines and I concur, it was too tall.
It is going to be one badass mustang 2! It is coming along nicely
rusty428cj
12-01-2015, 01:11 PM
The AOD is a tight fit so to make it easier to install we modified the trans tunnel
https://static1.pt-content.com/images/pt/2015/12/DSCN2228_zpsnq3wvprl-1.jpg
Also decided to fill some of the holes in the firewall
https://static1.pt-content.com/images/pt/2015/12/DSCN2338_zps6ho6g1f6-1.jpg
I also didn't like all the holes in the fender aprons
https://static1.pt-content.com/images/pt/2015/12/DSCN2339_zpsel5nyboj-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2340_zpsaakjqo0d-1.jpg
Crossmember was also modified for more clearance
https://static1.pt-content.com/images/pt/2015/12/DSCN2229_zps6h3qfioj-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2341_zpssjkdclpq-1.jpg
Mach1_Ron
12-02-2015, 06:21 AM
I Dig that Orange Color....
rusty428cj
12-03-2015, 06:07 AM
We made our own trans crossmember using some of the original and a thick piece of metal
https://static1.pt-content.com/images/pt/2015/12/DSCN2344_zpshhmknisz-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2345_zpsdbd9z6og-1.jpg
rhurley
12-03-2015, 07:05 AM
Rusty, You do a great job on all of these. Do you ever do filler over top of the SPI primer?
rusty428cj
12-03-2015, 08:14 AM
I epoxy prime the bare metal and then do my bodywork followed with another coat of SPI epoxy and the next day SPI Turbo primer.
wfo guy
12-03-2015, 04:30 PM
I'm surprised that no one makes engine mounts and they are different from all the other sbf mounts. There always seems to be a surprise in the project world. Good progress, Rusty. :)
rusty428cj
12-06-2015, 11:33 AM
I finished the bodywork in the engine compartment and sprayed a couple coats of SPI black epoxy. Next day I sprayed SPI Turbo urethane primer.
https://static1.pt-content.com/images/pt/2015/12/DSCN2355_zpsvbukwczd-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2359_zpsynjyxleg-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2366_zpsxprqkq7d-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2369_zpsz8ol78kz-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2370_zpsgqowloih-1.jpg
Red67Mustang
12-06-2015, 05:48 PM
Cool project! I had a '76 Cobra II in high school through college... It was such a blast to drive! Your project looks great, I like the bumper mods... Didn't even know those parts were available. Maybe the Mustang II is (slowly) gaining in popularity / aftermarket support? Though they were underpowered from the factory... It's still a SBF and once they've been rebuilt these cars are really great little hot rods.
chunger
12-08-2015, 07:47 PM
Nice work Rusty.
Is the purpose of the epoxy to seal the metal? Or does it just bond to metal better than regular primer?
Thanks!
Z06killinSBF
12-09-2015, 07:14 AM
Such awesome work as always. I love the little MII's
rusty428cj
Nice work Rusty.
Thanks!
Regular primer can absorb moisture epoxy does not.
DrFraZZy
01-24-2016, 04:26 PM
Any update Rusty?
Protour_Pinto
01-24-2016, 08:14 PM
Have you seen Brett Behrens' 1978 Mustang II? It has a V10,tube chassis and a Z06 Transaxle.
rusty428cj
01-25-2016, 08:08 AM
Any update Rusty?
No sitting on jack stands waiting to clean up the undercarriage. Busy working on customers cars.
rusty428cj
01-25-2016, 08:09 AM
Only pictures.
Protour_Pinto
01-25-2016, 09:01 AM
Have the customers come down and clean up your undercarriage!
DrFraZZy
03-09-2016, 04:33 AM
Any new update!?
rusty428cj
03-30-2016, 01:22 PM
I started working on my II again. I painted the back side of the doors
https://static1.pt-content.com/images/pt/2016/03/DSCN2862_zpsn35oer2r-1.jpg
Ben@SpeedTech
03-30-2016, 02:08 PM
Coming along nicely!
wfo guy
03-30-2016, 05:53 PM
Where's my sun glasses? :)
Peanut1959
03-30-2016, 06:21 PM
Great project! Subscribed.
rusty428cj
03-31-2016, 07:53 AM
Two coats of SPI white epoxy. A little wet sanding and this weekend it will be SPI Orange
https://static1.pt-content.com/images/pt/2016/03/DSCN2865_zps46zg9zyn-1.jpg
cbpldc
04-01-2016, 11:16 AM
You could leave it white all the way down the top and hood and have a dreamsicle!
Chris
rusty428cj
04-02-2016, 02:29 PM
Three coats SPI Orange and three coats of SPI Universal clear.
https://static1.pt-content.com/images/pt/2016/04/DSCN2867_zpscrbnrbtx-1.jpg
48prerunner
04-02-2016, 04:32 PM
I'm sure you checked this site outhttp://www.mustangiitech.net/index.php?option=com_content&view=article&id=54:v-8-motor-mount-rebuild&catid=43:bodychassis&Itemid=120
Thought it was weird you couldn't buy motor mounts but you were right. I always wondered if anybody would save the little mustang IIs very cool, and they kept the mustang name going for over 50 years.http://www.mustangii.net/forums/topic.asp?TOPIC_ID=10133
rusty428cj
04-10-2016, 09:40 AM
I had not planned on putting the Mustang II on a rotisserie but the more I thought about it I could not just leave the undercarriage looking like this. Brian and I (mostly Brian) fit it on the rotisserie yesterday.
https://static1.pt-content.com/images/pt/2016/04/DSCN2880_zps6egxsw0l-1.jpg
https://static1.pt-content.com/images/pt/2016/04/DSCN2881_zpspooh1nj2-1.jpg
rusty428cj
04-10-2016, 11:37 AM
Yesterday I sprayed 3 coats of SPI orange waiting 45 min between coats and today I sprayed 3 coats of SPI Universal clear waiting 30 min between coats.
https://static1.pt-content.com/images/pt/2016/04/DSCN2884_zpsbz5r4meh-1.jpg
https://static1.pt-content.com/images/pt/2016/04/DSCN2886_zpsfbiggqk7-1.jpg
wfo guy
04-10-2016, 02:56 PM
I fully understand everything you said in the last couple of posts. :)
rusty428cj
04-14-2016, 02:07 PM
The seats came in today from Mustangs Unlimited still waiting for the seat tracks
https://static1.pt-content.com/images/pt/2016/04/DSCN2903_zpsoi6k1x0w-1.jpg
rusty428cj
05-04-2016, 07:10 AM
Last weekend I decided it was time to spray a couple coats of SPI black epoxy on the undercarriage
https://static1.pt-content.com/images/pt/2016/05/DSCN2973_zpsnilofzvr-1.jpg
https://static1.pt-content.com/images/pt/2016/05/DSCN2981_zpszdorzw3y-1.jpg
Angelo
05-04-2016, 07:41 AM
This build is a pleasure to follow. Car and mods look great. Nice clean lines. Looking forward to following
rusty428cj
05-14-2016, 10:50 AM
Today I painted the hinges. I know its not a lot of progress but you can't install the doors, hood or rear hatch without them
https://static1.pt-content.com/images/pt/2016/05/DSCN3049_zpskrap3irf-1.jpg
https://static1.pt-content.com/images/pt/2016/05/DSCN3048_zps0u70jzqw-1.jpg
wfo guy
05-14-2016, 04:22 PM
It's still progress. Unless a paint booth is large enough to hold all the parts, it takes time! :)
Zspoiler
05-14-2016, 06:46 PM
Its nice to see a variety of cars .Your look like you are doing a vary nice build.It reminds me of the 1978 Monroe Mustang II "Handler" car.That was a Cover car for Hot Rod Magazine.And many other Publications.
Peanut1959
05-15-2016, 06:29 AM
Any progress is good progress!
rusty428cj
05-21-2016, 01:25 PM
Two coats of SPI white epoxy. Almost ready for paint
https://static1.pt-content.com/images/pt/2016/05/DSCN3101_zpsjnxmzqek-1.jpg
https://static1.pt-content.com/images/pt/2016/05/DSCN3103_zpsftv96pzb-1.jpg
rusty428cj
07-17-2016, 07:50 AM
After I block sanded the body I found a few areas that needed a little more work.
https://static1.pt-content.com/images/pt/2016/07/DSCN3462_zps0kylx3b1-1.jpg
https://static1.pt-content.com/images/pt/2016/07/DSCN3463_zpsbhyve907-1.jpg
https://static1.pt-content.com/images/pt/2016/07/DSCN3464_zpswod1f9bw-1.jpg
I had forgotten how hard it is to see any imperfections in white primer. I should have sprayed gray and the white just before spraying orange.
Two more coats of epoxy
https://static1.pt-content.com/images/pt/2016/07/DSCN3470_zpsqk3meyrk-1.jpg
rusty428cj
08-18-2016, 03:59 AM
I wet sanded the body with 400 getting it ready for paint
https://static1.pt-content.com/images/pt/2016/08/DSCN3588_zps8do2rcft-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3590_zpstquqez3z-1.jpg
Windshield was removed
https://static1.pt-content.com/images/pt/2016/08/DSCN3625_zpshurw8kx4-1.jpg
Rear glass installed in the hatch
https://static1.pt-content.com/images/pt/2016/08/DSCN3623_zpsyq9gvtqg-1.jpg
rusty428cj
08-20-2016, 08:54 AM
Today Brian cleaned all that nasty mess from under the windshield.
No rust in the right windshield pillar.
https://static1.pt-content.com/images/pt/2016/08/DSCN3654_zpsb6bxz4bb-1.jpg
He found this on the drivers side.
https://static1.pt-content.com/images/pt/2016/08/DSCN3655_zpsvaevb4bh-1.jpg
Brian cut out the rust and welded in a patch.
https://static1.pt-content.com/images/pt/2016/08/DSCN3659_zpsvdwfipld-1.jpg
wfo guy
08-20-2016, 01:55 PM
How many languages can we say " Oh Sh**" ? :)
rusty428cj
08-23-2016, 04:45 AM
I finished wet sanding all that is left before paint is for Brian to tape and I will be spraying orange this weekend.
https://static1.pt-content.com/images/pt/2016/08/DSCN3673_zpsnveexpyd-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3675_zps8ql4mp2j-1.jpg
cbpldc
08-23-2016, 07:04 AM
Good to see updates on this! Looking good.
Chris
rusty428cj
08-26-2016, 03:46 AM
Yesterday before Brian went home he got the body ready for paint. Finished taping, moved it in the booth and wiped it down with SPI wax and grease remover.
https://static1.pt-content.com/images/pt/2016/08/DSCN3695_zps9b3mywf3-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3697_zpsmkrvftq0-1.jpg
I got up early and was at the shop at 5:30 and mixed up a cup of reduced SPI white epoxy and sprayed a sealer coat. Around 9 I will start spraying orange.
https://static1.pt-content.com/images/pt/2016/08/DSCN3699_zpsalowl1w2-1.jpg
DrFraZZy
08-26-2016, 04:28 AM
whoooo! I can’t wait to see it painted! What wheels are you going with?
Z06killinSBF
08-26-2016, 06:53 AM
Should be orange by now!!
jlcustomz
08-26-2016, 07:48 AM
Lookin good Rusty. I'm not a ford person at heart, but a couple of the first vehicles I drove were a 73' ranchero with a 302 & a factory v-8 chevy Monza. A v-8 mustang 2 is kinda like a combo of those 2 vehicles, should make a pretty cool daily driver if you add a few modern comforts to it.
rusty428cj
08-26-2016, 08:09 AM
Two coats one more to go.
rusty428cj
08-26-2016, 11:34 AM
Three coats of SPI Orange tomorrow I will spray clear.
https://static1.pt-content.com/images/pt/2016/08/DSCN3701_zpsw5qx9f4u-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3703_zpsf49fenxk-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3704_zpsyujk6xg1-1.jpg
1965gp
08-26-2016, 08:54 PM
Love the color
rusty428cj
08-27-2016, 06:40 AM
Three coats of SPI Universal Clear
https://static1.pt-content.com/images/pt/2016/08/DSCN3725_zpsxgfmqy6p-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3731_zpskbyi2igq-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3718_zpsltwjxjwf-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3714_zpsa0oks7j1-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3711_zps5pjoqvkd-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3710_zpskf7p28jx-1.jpg
Motown 454
08-27-2016, 10:19 AM
Sweet! I like the color.
wfo guy
08-27-2016, 12:27 PM
More progress. :)
Fahrenschnell
09-02-2016, 10:06 AM
That is a great color for that car.
rusty428cj
09-16-2016, 06:47 AM
It is hard to get the true color. In the booth it's to light and outside looks red. It is somewhere in between. Brian has been wet sanding the body and should start buffing soon.
https://static1.pt-content.com/images/pt/2016/09/DSCN3735_zpsvex53yhq-1.jpg
Jays68
09-16-2016, 07:22 AM
Wow! Very nice. I really like the color.....then again I'm a little partial to orange lol
rusty428cj
09-17-2016, 03:57 PM
Brian wet sanding
https://static1.pt-content.com/images/pt/2016/09/DSCN3765_zpsaf6s2ubn-1.jpg
chunger
09-18-2016, 07:22 PM
Looking great Rusty! I see what you mean about the color changing with the light.
rusty428cj
10-22-2016, 01:21 PM
Yesterday I sprayed two coats of SPI white epoxy and this morning three coats of SPI Orange followed with three coats of SPI Universal clear late this afternoon.
https://static1.pt-content.com/images/pt/2016/10/DSCN4002_zpsg1je0tk9-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN4006_zps04y4frji-1.jpg
rusty428cj
12-10-2016, 10:34 AM
Brian finished wet sanding and buffing the body and hatch.
https://static1.pt-content.com/images/pt/2016/12/DSCN4153_zpsshtu67kz-1.jpg
https://static1.pt-content.com/images/pt/2016/12/DSCN4114_zpse6uzazsr-1.jpg
wfo guy
12-11-2016, 06:32 AM
Have you found it to be advantageous to wait a while before cutting and buffing?
rusty428cj
12-11-2016, 08:57 AM
It is a good idea so the solvents have a chance to get out and everything settles down.
rusty428cj
12-16-2016, 09:45 AM
Off the rotisserie and the assembly begins
https://static1.pt-content.com/images/pt/2016/12/Mustang20II201_zps0uyqnsmx-1.jpg
DrFraZZy
12-16-2016, 12:12 PM
Whooooooot!! I have been looking forward to the assemble for awhile!
wfo guy
12-17-2016, 05:17 AM
I'm looking forward to the drive report. :)
rusty428cj
12-19-2016, 01:25 PM
Today we lined up the rear hatch and bumper
https://static1.pt-content.com/images/pt/2016/12/Mustang20II204_zpscsaryef7-1.jpg
https://static1.pt-content.com/images/pt/2016/12/Mustang20II205_zpsf9dxvptk-1.jpg
rusty428cj
12-21-2016, 09:48 AM
Test fitting the Corbeau seats.
https://static1.pt-content.com/images/pt/2016/12/Seats_zpslysikcef-1.jpg
The seats are hitting the door bar and the brackets don't line up with the holes in the floor. We need to drill new holes 1 1/2" toward the transmission tunnel in the seat brackets.
https://static1.pt-content.com/images/pt/2016/12/seat20bracket_zps6v3vt6c8-1.jpg
It's a tight fit but with the new holes in the brackets they fit.
https://static1.pt-content.com/images/pt/2016/12/Mustang20II2010_zpscz8d1siz-1.jpg
https://static1.pt-content.com/images/pt/2016/12/Mustang20II2012_zps303y4bht-1.jpg
We were going to use this Flaming River steering wheel in a 1967 Fairlane race car with a quick release Flaming River column but it was to close to the dash board. A couple of years ago Brian gave me a Momo steering wheel for my 1968 restomod Coupe for Christmas and the adapter would not work with the Ididit steering column. They both work great on the Mustang II steering column and I had some left over Dynamat from the 1968 Coupe.
https://static1.pt-content.com/images/pt/2016/12/Mustang20II203_zpsznmdm6iw-1.jpg
wfo guy
12-21-2016, 04:26 PM
Kool!
rusty428cj
12-23-2016, 05:39 AM
Brian finished buffing and we installed the drivers door getting ready to install the right door today.
https://static1.pt-content.com/images/pt/2016/12/Mustang20II2014_zpsjta1nena-1.jpg
https://static1.pt-content.com/images/pt/2016/12/Mustang20II2013_zpsbkgphn24-1.jpg
rusty428cj
12-23-2016, 01:17 PM
Right door installed
https://static1.pt-content.com/images/pt/2016/12/Mustang20II2015_zpsxebybvra-1.jpg
Bossed
12-24-2016, 05:08 PM
Rusty, it's beautiful. Is that SPI Universal Clear? How many coats of clear?
1965gp
12-24-2016, 06:01 PM
The car looks great. I love these with t tops.
rusty428cj
12-26-2016, 05:25 AM
Yes 3 coats
Wraith
12-26-2016, 05:39 PM
Love this build.
One of the scariest rides I drove was a 78' Cobra II with a few mods and a four speed back in high school, should have bought that car. lol
rusty428cj
01-04-2017, 09:03 AM
Outside you can see it is orange
https://static1.pt-content.com/images/pt/2017/01/Mustang20II2016_zpsux6kikjp-1.jpg
https://static1.pt-content.com/images/pt/2017/01/Mustang20II2017_zpsk1swfjvl-1.jpg
https://static1.pt-content.com/images/pt/2017/01/Mustang20II2019_zpsprsriibz-1.jpg
Moved to the storage/assembly shop.
https://static1.pt-content.com/images/pt/2017/01/Mustang20II2021_zps8jo71lh3-1.jpg
Peanut1959
01-06-2017, 09:47 PM
Damn!!! That is a great shade! What did you say it was, again?
rusty428cj
01-07-2017, 07:39 AM
SPI Orange www.southernpolyurethanes.com I have been using their products in my shop since 2005.
rusty428cj
01-28-2017, 11:46 AM
Brian finished wet sanding the fenders next week time for buffing.
https://static1.pt-content.com/images/pt/2017/01/Mustang20II2025_zps62cvndjg-1.jpg
rusty428cj
04-03-2017, 11:05 AM
Brian finished buffing the fenders and hood and has them on the car. Waiting to finish the grille panel and front bumper.
https://static1.pt-content.com/images/pt/2017/04/20170324_123521_resized_zpsvgwa82kw-1.jpg
https://static1.pt-content.com/images/pt/2017/04/20170403_102535_resized_zpsjm96d0gb-1.jpg
https://static1.pt-content.com/images/pt/2017/04/20170403_102510_resized_zpsk92lqsn6-1.jpg
rusty428cj
04-04-2017, 04:30 AM
Not sure what I did wrong yesterday but here are the photos
https://static1.pt-content.com/images/pt/2017/04/20170324_123521_resized_zpssaei4886-1.jpg
https://static1.pt-content.com/images/pt/2017/04/20170403_102510_resized_zpsjzq7ki9h-1.jpg
https://static1.pt-content.com/images/pt/2017/04/20170403_102531_resized_zpsatccivle-1.jpg
Bossed
04-22-2017, 04:30 AM
Beautiful color, can't wait to see more.
rusty428cj
08-23-2017, 06:52 AM
We were moving cars around and I thought it was a good time for a couple of photos while it was outside.
https://static1.pt-content.com/images/pt/2017/08/41_zpswrpf6qff-1.jpg
https://static1.pt-content.com/images/pt/2017/08/40_zps5oji53sn-1.jpg
rusty428cj
11-24-2017, 07:06 AM
I made a little progress on the Mustang II project. I have the gas tank installed
https://static1.pt-content.com/images/pt/2017/11/45_zpsdacxc56p-1.jpg
https://static1.pt-content.com/images/pt/2017/11/46_zpsnd8qc9jq-1.jpg
I modified fuel filler tubes from an Eleanor project that we didn't use to fit the II
https://static1.pt-content.com/images/pt/2017/11/49_zpssxkof4mm-1.jpg
Epoxy primed
https://static1.pt-content.com/images/pt/2017/11/51_zpsqlxagh0u-1.jpg
https://static1.pt-content.com/images/pt/2017/11/52_zpslktnoojm-1.jpg
https://static1.pt-content.com/images/pt/2017/11/53_zpsnloot7aj-1.jpg
Front sway bar installed
https://static1.pt-content.com/images/pt/2017/11/48_zps3ucf29ix-1.jpg
Rear brakes left over from a Wilwood upgrade on another project
https://static1.pt-content.com/images/pt/2017/11/47_zpsplm4rnht-1.jpg
Gas cap
https://static1.pt-content.com/images/pt/2017/11/55_zpsk7pgwica-1.jpg
wfo guy
11-24-2017, 05:00 PM
I'm kind of excited for you on this project. Me being and ex-drag racer, the concept of large engine in a small body makes me smile. :) I think this will be a hoot to drive. :)
rusty428cj
02-10-2018, 02:53 PM
I just traded a C6 transmission and converter that was used in my race car (now use a C4 behind the 428 CJ) for this 302 that has very few hours on it to install in my Mustang II
https://static1.pt-content.com/images/pt/2018/02/324_zpswda3ha7d-1.jpeg
wfo guy
02-10-2018, 04:46 PM
One step closer. :)
Bossed
02-10-2018, 06:03 PM
Looking great Rusty
Peanut1959
02-11-2018, 09:10 AM
Glad to see this build jump back up to the top of my subscribed threads! Looking forward to more progress after winter turns to spring.
rusty428cj
02-17-2018, 06:51 PM
Today the 302 was dropped off at the shop. It was in a Mustang that was upgraded to a 427 small block.
https://static1.pt-content.com/images/pt/2018/02/329_zpsuzyobgsp-1.jpg
https://static1.pt-content.com/images/pt/2018/02/328_zps8f9bxik4-1.jpg
Looks new
https://static1.pt-content.com/images/pt/2018/02/330_zpssjbmkokv-1.jpg
https://static1.pt-content.com/images/pt/2018/02/334_zpsuxi8yxex-1.jpg
https://static1.pt-content.com/images/pt/2018/02/331_zpsbwwkw6ar-1.jpg
I need to order a flex plate for the AOD. I'm also going to replace the water pump, harmonic balancer, fuel pump, intake and valve covers plus the correct oil pan for the Mustang II.
Now I need to get busy installing brake lines and fuel line before I install the engine.
https://static1.pt-content.com/images/pt/2018/02/339_zpsrdg0defi-1.jpg
wfo guy
02-18-2018, 03:24 AM
Did you find out what internals are in the engine?
rusty428cj
02-18-2018, 04:01 AM
No all I know is the cam isn't stock.
Bossed
02-18-2018, 06:40 AM
Rusty, did you massage firewall/tunnel for the AOD ? I had one with a factory 302/automatic. I remember it used a very small bell housing. Just curious.
rusty428cj
02-18-2018, 10:41 AM
Yes we modified the firewall, tunnel and crossmember to get it to fit.
rusty428cj
03-24-2018, 06:23 PM
I ordered a Ron Francis wiring harness and after looking at the back of the dash and seeing wires held together with masking tape I decided to remove everything and start over.
https://static1.pt-content.com/images/pt/2018/03/343_zpsu7scifq1-1.jpg
https://static1.pt-content.com/images/pt/2018/03/344_zpsz7hr95g7-1.jpg
https://static1.pt-content.com/images/pt/2018/03/345_zpsispl7cy4-1.jpg
I will have to enlarge the openings to fit the new 4" Speedhut speedometer and tach that I ordered
https://static1.pt-content.com/images/pt/2018/03/350_zpsjmoat3k8-1.png
https://static1.pt-content.com/images/pt/2018/03/351_zpsylzgkdws-1.png
I will also have to modify the dash to fit the 2 1/16" gauges
https://static1.pt-content.com/images/pt/2018/03/353_zpssecclywl-1.png
https://static1.pt-content.com/images/pt/2018/03/352_zpszdx3cbkm-1.png
https://static1.pt-content.com/images/pt/2018/03/354_zpst7vf2fzr-1.png
rusty428cj
04-23-2018, 04:21 AM
Speedhut gauges came in. Each gauge has a bag with wires, sending unit or whatever is needed to hook it up.
https://static1.pt-content.com/images/pt/2018/04/368_zpsejpuzvrz-1.jpg
https://static1.pt-content.com/images/pt/2018/04/369_zpsswpgelcu-1.jpg
I have to modify the back side of the gauge panel.
https://static1.pt-content.com/images/pt/2018/04/366_zpsco4xhycw-1.jpg
https://static1.pt-content.com/images/pt/2018/04/367_zpsagpmvtmq-1.jpg
https://static1.pt-content.com/images/pt/2018/04/373_zpsjv5i8ecm-1.jpg
https://static1.pt-content.com/images/pt/2018/04/372_zpseziuo04f-1.jpg
I used a half round file to enlarge the hole.
I still have to paint the dash trim black
https://static1.pt-content.com/images/pt/2018/04/376_zpsubtp8mif-1.jpg
https://static1.pt-content.com/images/pt/2018/04/377_zps4goxpzdu-1.jpg
https://static1.pt-content.com/images/pt/2018/04/378_zpspx1opzu0-1.jpg
https://static1.pt-content.com/images/pt/2018/04/379_zpsa1wmyzbv-1.jpg
wfo guy
04-23-2018, 08:38 AM
That is SOOO much better. :)
Chad-1stGen
04-23-2018, 10:32 AM
Did you just wire brush the fake wood paneling off to get the brushed aluminum finish?
rusty428cj
04-23-2018, 11:46 AM
It's hard to believe but someone makes it for the Mustang II. I have to glue it on.
Wraith
04-23-2018, 04:08 PM
Wow that looks good!
rusty428cj
05-14-2018, 12:03 PM
Had to make a filler piece to fit the Vintage Air controls
https://static1.pt-content.com/images/pt/2018/05/380_zpsiferhotb-1.jpg
Sanded and painted
https://static1.pt-content.com/images/pt/2018/05/383_zpsc3htvetl-1.jpg
https://static1.pt-content.com/images/pt/2018/05/382_zps5h6q6xxp-1.jpg
https://static1.pt-content.com/images/pt/2018/05/381_zpshzwr3r1c-1.jpg
The stainless goes on next.
The Vintage Air fits with the modified tunnel and the hoses will go out the side. We have to make brackets since there is no kit for a Mustang II
https://static1.pt-content.com/images/pt/2018/05/384_zps2bvq8cod-1.jpg
https://static1.pt-content.com/images/pt/2018/05/386_zpszk60wrpm-1.jpg
https://static1.pt-content.com/images/pt/2018/05/387_zpsbhaadvig-1.jpg
rusty428cj
09-30-2018, 11:17 AM
I have decided it's time to start working on this project again. Dashboard is ready to install but need to fabricate brackets for the AC first.
https://static1.pt-content.com/images/pt/2018/09/393_zpskavplkgr-1.jpg
J-440
09-30-2018, 11:36 AM
Great to see something different. Nice work. I can foresee some big tires, big flares, and a big wing circa IMSA racing in the 70's. Cool car!!
andrewb70
09-30-2018, 11:44 AM
The dash looks fantastic!
rusty428cj
09-30-2018, 12:33 PM
I was going to add flares but decided I don't have a lot of spare time and needed to cut back on anymore custom bodywork.
wfo guy
09-30-2018, 02:33 PM
I hope you have enough energy to finish this. I have thought this was a neat project from the beginning. :)
rusty428cj
01-11-2019, 05:48 AM
I don't think I showed how it looks with the taillights installed.
https://static1.pt-content.com/images/pt/2019/01/395_zpsnb9zvekl-1.jpg
DrFraZZy
01-11-2019, 06:04 AM
It looks clean and sharp! Keep the updating coming. I look forward to see this on the road. There s not many out there on the road.
Zspoiler
01-11-2019, 07:43 AM
Thats a lot cleaner look
Peanut1959
01-12-2019, 09:05 PM
Sharp! Nice to have an update. Looking forward to more!
Iansr1
01-23-2019, 08:47 PM
Thanks for updating this post every now and again, it's good to see someone documenting their journey on these cars. It looks BEAUTIFUL.
rusty428cj
04-29-2020, 04:54 AM
The engine looked great until we took it apart and found the machine work was not done properly and is mostly junk. We have decided to rebuild the original engine.
I'm not finished making all the brake lines.
https://static1.pt-content.com/images/pt/2020/04/365_zpsooqhftym-1.jpg
https://static1.pt-content.com/images/pt/2020/04/364_zpspgnxsh9i-1.jpg
wfo guy
04-29-2020, 08:03 AM
That's too bad on your part. I'm not surprised at your comment, though. A good machine shop for people that understand correct is really hard to find. :)
Fordfanatic
05-12-2020, 07:55 AM
I love the roll bar. I am doing a 78 King Cobra at the moment. I see that you got it from S&W. I went on their web site and found the kit but it has straight side bars and I don't see an option for the curved bars. Did you have to call them to have them done that way or did you do them yourself?
rusty428cj
05-16-2020, 12:06 PM
It was an option when I bought it years ago.
chunger
03-30-2021, 10:40 PM
Hi Rusty, were there any more updates on this project?
rusty428cj
11-29-2021, 10:22 AM
I still don't have a drivetrain but I towed it up to Mustang II reunion last year and also a few other shows and it was a hit. I got a few restoration jobs because of the paint job. 194281194282194283194284194285194286
Teddyzee
11-29-2021, 12:10 PM
Great to see an update!
68Formula
11-29-2021, 12:41 PM
Wow!
wfo guy
11-30-2021, 05:30 AM
I'm a little tickled at the now hiring signs but I fully understand the lack of employees. :)
rusty428cj
12-01-2021, 09:08 AM
That was last year and I did hire someone and he is still here!!
68Formula
12-01-2021, 03:48 PM
I don't. Where the heck did everyone go? Did we populate Mars already and those of us still on earth simply weren't told? :dunno:
Peanut1959
12-01-2021, 08:08 PM
This build will certainly change some minds as it pertains to the suitability of Mustang IIs as legit cool cars!
jaybee
12-08-2021, 06:54 PM
Good to see this project back! It's a very cool and unique car.
rusty428cj
12-10-2021, 07:06 AM
The headliner was installed before I went to any shows.
