View Full Version : 69 Camaro - trouble with QA1 shocks mounting to Cal Trac shock mounts
2BFAST
10-13-2015, 03:25 AM
Having an issue with the shocks to mount to the lower shock mounts. See below. The body of the shock is hitting the mount.
https://static1.pt-content.com/images/pt/2015/10/IMG_1641_zps5mr2tmuv-1.jpg (http://s3.photobucket.com/user/2bfast/media/camaro/IMG_1641_zps5mr2tmuv.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/IMG_1640_zps774acdqa-1.jpg (http://s3.photobucket.com/user/2bfast/media/camaro/IMG_1640_zps774acdqa.jpg.html)
CPP drop leafs are being used. Which I don't think that's the issue.
Z06vet
10-13-2015, 04:22 AM
That lower shock mount looks a bit different than the factory one. Could just be the picture. Is the mount part of the cal trac or is that the factory multi leaf plate? Either way I think you will need to use the factory shock mounting bolt. It has a built in spacer & bolts to the lower spring plate.
2BFAST
10-13-2015, 05:52 AM
They are the lower shock plates for the cal trac bars
HandOverFist
10-16-2015, 04:11 AM
I don't have a good picture of it, but like mentioned above you need a shock stud with built-in spacer and also re-drill the mounts 1" higher and at a diagonal to the original. I have the original shock mounting hole indicated in the attached image. Also clear the dbl adjustable Viking shocks currently on the car.
https://static1.pt-content.com/images/pt/2015/10/shockmountpoint_zpsfd963222-1.jpg
