View Full Version : Larger Wilwood Brakes on Granada Spindles
outrgus
10-11-2015, 07:32 PM
Thought i would throw some pics up of how i installed some Wilwood 12.19 rotors and calipers to my granada spindles.
Here are the part numbers i used in the conversion.
120-6816 (black dynalite 4 piston callipers)
270-7287 (hub assemblies)
300-3099 (rotor adaptors)
160-7103/04 (12.19 inch zinc drilled/ slotted rotors)
220-12168 (Brake line kit)
Custom made caliper mount for granada spindle.
I had purchaces all these parts from a fellow member on a different forum(all new and never installed for $600) and was told they would fit a granada spindle. When i recievied the parts, i found that the caliper bracket was intended for a mustang II spindle and did not work for my granada spindle, but had a simular design.
Since i already had the hubs/rotors and adapter that fit my spindles, I designed my own caliper bracket out of cardboard, and got them made on a plazma cutter for $50. I cut the treaded portion out of the mustang II bracket and welded it into my bracket i had made.
I have well over 200 miles on the new set-up, and they work great. Night and day difference from the granada 11" brake set-up.https://www.pro-touring.com/attachment.php?attachmentid=118291&stc=1https://www.pro-touring.com/attachment.php?attachmentid=118292&stc=1https://www.pro-touring.com/attachment.php?attachmentid=118293&stc=1https://www.pro-touring.com/attachment.php?attachmentid=118294&stc=1https://www.pro-touring.com/attachment.php?attachmentid=118295&stc=1https://www.pro-touring.com/attachment.php?attachmentid=118296&stc=1
