ablake211
10-07-2015, 07:28 AM
I had a blast building this 1969 Camaro X-11 into a killer street car. Truly I enjoy the builds and would like to consider moving this to consider building some other projects that I kick around in my head. Located in Buffalo NY
Price drop!
43K OBO
1969 Camaro - 6.0/ T56/ Twin Turbo
Motor/Fuel – Running on Holley EFI – 705rwhp 15psi
LQ4 from a 2006 – New style rods. New rod bearings and complete motor inspection this winter.
OEM ECU with HP Tuners
BTR Double valve springs, 7.4 pushrods(comp)
Speed Inc TU1.5 Cam
LS6 Intake Manifold/TB
Alper studs
LS9 Head Gaskets
New Water pump, alt, crank pulley
80lbs seimens inj.
Holley Rails
Aeromotve FPR
Entire fuel system made using stainless line with AN fittings
Holley HP-1800 pump
Sumped new stock tank
Car shop 1" back mounts
Turbo Kit
Hand fabricated by yours truly you will see I put a lot of effort into the layout of my kits and engine bays. I take great pride in what I build and I believe the pictures/quality will show this.
On3 T70s .68ar spool amazingly
Tial MVS gates -10psi spring (560rwhp daily mode)
Truck manifold based kit modified to be forward facing
All stainless, back purged welded
4" IC with top exit
Trans
Fully Built T56
McLeod Twin Disc Clutch + Hydraulics
Poly mount on BMR swap
Rear
8.5” 10bolt / 3.73s / Rebuilt recently nice and quiet
Brakes/Wheels/Tires
C5 Corvette front disc conversion
Rear disc
Adj willwood prop valve
18” staggered wheels with ~500mi Nitto 555 tires all around
Body/Paint/Interior/Chassis
All metal! We did a lot of work to get this body back to being where it is. Still a driver but the body/paint is a solid 8/10 and I’m rather picky.
Painted GM Ashen Grey Metallic using PPG products
100% new glass in the entire car(could use minor adjustment on windows)
All new trim
Interior is the “delux” and I believe it is repro parts. I did not change much interior wise. Very nice condition. Could use a headliner.
Replaced the commonly rusty passenger inner fender/battery tray
Replaced the core support
New driver fender and both rear quarters
All new energy suspension body bushings
BMR Subframe Connectors
All new shocks, Koni/Hotchkis
Hotchkis Front sway bar
Custom made chromoly driveshaft
It has much, much, much more but figured I would keep it to the basics. I would suggest if someone not local wants to see it we can video chat via facetime if you have an apple device
Full build/Pictures
http://s307.photobucket.com/user/ablake211/library/?view=recent&page=1
Someone take this and drive the hell out of it!
69 Camaro LS Twin Turbo - YouTube (https://www.youtube.com/watch?v=eImEJZbhuyo)
https://www.pro-touring.com/attachment.php?attachmentid=118076&stc=1
https://static1.pt-content.com/images/pt/2015/10/80undefined_a22063804770d0b473019b4e510f-1.png
https://www.pro-touring.com/attachment.php?attachmentid=118074&stc=1
https://www.pro-touring.com/attachment.php?attachmentid=118075&stc=1
https://static1.pt-content.com/images/pt/2015/10/80undefined_800659a0a2df324fa62d94cdd25c-1.png
https://static1.pt-content.com/images/pt/2015/10/80undefined_42806e9abd7cbec17ecbce1975f9-1.png
https://static1.pt-content.com/images/pt/2015/10/80undefined_95eeda18d19a677e615a43fa9367-1.png
https://static1.pt-content.com/images/pt/2015/10/80photo410_zpsd07234cf_b542412167ca4db49-1.jpg
https://static1.pt-content.com/images/pt/2015/10/80undefined_019f71828b3cb38b320a67d5f691-1.png
https://static1.pt-content.com/images/pt/2015/10/80undefined_7ae555582e80299c008c99feac11-1.png
https://static1.pt-content.com/images/pt/2015/10/80undefined_28b9409d09941847b3e0c842a1ed-1.png
https://static1.pt-content.com/images/pt/2015/10/80undefined_faa378d01ae2054fa35a9d789fdf-1.png
Price drop!
43K OBO
Speed Inc TU1.5 Cam
Alper studs
LS9 Head Gaskets
80lbs seimens inj.
Holley Rails
Aeromotve FPR
Holley HP-1800 pump
Turbo Kit
4" IC with top exit
Trans
Fully Built T56
Rear
Brakes/Wheels/Tires
Rear disc
All new trim
Full build/Pictures
