View Full Version : Need advice on carb selection....
HotRod47
09-25-2015, 03:39 PM
I recently acquired a 66 Chevelle that has a 454 in it. It has a very stout cam, has Rectangular port 69 Corvette heads, and open plenum Weiand intake and a AED 850 carb on it now. This is a 4 speed car if that matters much. I just did a rear gear swap to make the car more drivable to my liking. The guy liked stop light to stop light cruising and had 4:88's in it!
So with 3:55's the car is definitely more drivable. With the cam that is in it I need to pull away from a light or stop sign with the RPM's up higher then I like. I have been told by many to swap out the intake and carb to a duel plane intake like and Edelbrock RPM or something like that. So that is next, but what about the carb? What do I really need?
Planning to most likely get a Holley, but which one? Is a 750 the only way to go hear? Is the Street Avenger 670 too small?
Remember, this is a street car. I will never take it to any type of track, drag or autocross. Cruise nights, local car shows, out with friends etc.
Appreciate any advice you guys can offer.
Glenn
65 drop top
09-25-2015, 04:01 PM
Swapping the intake and carb may help increase bottom end torque, but with a big block you will already have plenty. It sounds to me like maybe you have too much cam for the street. Do you know the cam specs?
Sean Cooke
09-25-2015, 10:24 PM
http://www.gtsparkplugs.com/CarbCFMCalc.html
Not the end all solution for picking a Carb but maybe a guide to get you in the ballpark..
TheJDMan
10-15-2015, 02:22 PM
Personally, I would not spend any money on a carb. Take a look at FITech they offer a reasonably priced throttle body EFI which will outperform a carb.
http://fitechefi.com/
another69
10-18-2015, 12:35 PM
I had a great experience with Pro Systems when I bought my carb from them in 2007ish. Best carb I ever had, no doubt. You give them all of your vehicle info and they "build" a carb to match. That being said, this year I swapped to efi and will never go back.
HotRod47
10-18-2015, 02:04 PM
I am going to install EFI on my project car, but on this one I just want to replace the carb and call it a day. I plan on selling this next year and really don't want to invest the money to put injection on it.
another69
10-18-2015, 03:00 PM
Nothing wrong with going with a carb, but are you sure that you have a carb issue? Do you know your cam specs and your compression ratio? If those are mismatched you may never make good low end torque. Same goes for a motor with a big cam built for high RPM- generally low RPM power suffers. You may just need a new intake and flat tappet cam, which would be cheaper than a high end carb. More info on the motor would help...
matt816
10-19-2015, 11:46 AM
Tune the current setup. Plugs, timing and idle circuits. Measure your vacuum at idle, 850-900 rpms. below 10" and your cam most likely doesn't like the new gears. Im betting its not tuned for normal cruising and the cam is too big
HotRod47
10-19-2015, 02:49 PM
I know it isn't a carb issue per se. But I am still trying to get an idea on what people suggest.
Big block with a huge high RPM cam, an open plenum Weiand intake and an 850 AED carb. Carb has been set up to flow at a little over 900 cfm. The engine dyno'd at 589hp as is. HP is fine, but the set up and parts selection is way too much for the street. I was hoping to get away with a intake and carb swap, but the more I drive it, the clearer it has become that I must do a cam as well. I have consulted with Competition Cams as they did the custom grind on the cam that is in the engine. I want to find something compatible with the rest of the engine, heads etc. I have done that now. New cam on order, as well as a Edelbrock RPM intake. Still unsure what I should get for the carb though.
Glenn
another69
10-19-2015, 05:34 PM
Sounds like a pretty stout big block! What makes you think that you can't use the AED that you have now? Is it a mech. secondaries? For that motor it would probably be best. If you are asking for suggestions, I would say the best carb will be one custom built by someone like Pro Systems. The next best thing would be to tune what you have now VIA a wideband O2 gauge.
See you have sold the car, never mind
good day.........
sam 74
02-05-2016, 03:10 PM
take a look at FITech, its worth it, but if you're set on a carb i wouldn't go smaller than a 750 with any kind of work done to a big block, you may want to consider an HP series type of carb, or if you have the specs of your motor you can always have a carb custom built to your motor which is usually what i do with high performance stuff, they just run better than an out of the box carb.
