View Full Version : "dustless blasting"
krom
09-22-2015, 05:40 AM
Has anyone used dustless blasting to strip a car?
http://dustlessblasting.com/
Is there any special prep required before primer, haven't been able to find any info anywhere.
dontlifttoshift
09-22-2015, 05:47 AM
Looks like you would metal prep just like usual.
My concern is the pressure. Common misconception about the heat from sandblasting warping sheetmetal, think of it as thousands of little hammers. So like anything, will only work as good as the guy holding the nozzle.
sccacuda
09-22-2015, 11:11 AM
My concern is the water! They use a baking soda media in the water jet stream. Baking soda has to be neutralized with water or will react with paint. Something about H2O and bare metal that makes me uncomfortable.
XLexusTech
09-22-2015, 03:09 PM
So what's a better option? Chemical strip? If so what stripper?
DA with 200 ?
dhutton
09-22-2015, 03:48 PM
DA with 200 ?
I use a combination of blasting and a DA with 80 grit. Flat panels are DA'd, door jambs etc are blasted.
Don
minendrews68
09-22-2015, 03:49 PM
If I'm not mistaken, in the video, it says media is recycled glass media, not baking soda.
krom
09-22-2015, 04:14 PM
found that it uses holdtight 102 as the rust preventative
http://www.holdtight.com/
and glass as the abrasive. Just looking for anyone who has used it on a car before. Don't want to open a can of worms that make it impossible to get the paint to stick
Tincup
09-22-2015, 06:13 PM
My friend had his dad's 37 Ford done. It warped the doors where the guy moved the nozzle ( too much pressure ). He would not do it again.
Poncho72
11-15-2015, 07:10 PM
I am co-owner of a dustless blasting business, and I I have used all types of blast techniques and media. By far, crushed glass is the preferred media. I blast with dry or wet (using "hold-tight) and IMO this is the best method for auto body. I have blasted everything from heavy machinery to brick walls, and even wood siding and technique and the proper grade of media will make all the difference. The thinnest metal that I blasted was a hood on a c class Mercedes without the slightest wave afterwards. Sand is too rough and creates a lot of heat which equates to more warpage. baking soda only removes paint, nothing else, and no paint manufacturer will stand behind paint over a soda blast job since it is very hard to neutralize the soda remnants that hide in crevices. Finding the right blaster is key to getting a good job.
SD67
04-04-2018, 09:15 PM
Bringing up an old thread in the hopes that someone has used theses guys in SoCal: http://www.californiadustlessblasting.com/auto.html
Any recent experiences with this technology? Using glass media remove rust too?
krom
04-05-2018, 04:49 PM
I was too nervous to be a guinea pig. Had my car done with a traditional blaster and glass media
SD67
04-05-2018, 09:29 PM
Yeah, lots riding on this. Kinda like the idea of the DA on flat panels and blasting the jams.
WOLF1732
04-06-2018, 03:36 AM
No problem mix any rust inhibitor in the water . This is a standard practice in vibratory finishing on steel parts
Zl1427
12-30-2018, 03:40 PM
Some have mentioned, DA. What does it stand for ? Thanks
dhutton
12-30-2018, 03:55 PM
Dual Action random orbit pneumatic sander. Most guys use a 6”.
Something like this:
https://www.ebay.com/itm/Ingersoll-Rand-311A-Air-Dual-Action-Quiet-Sander-6-Pad-DA-Sander/372287387322?epid=1911823100&hash=item56ae0eb6ba:g:a5EAAOSwH8ta3~7G
Don
Timmah
12-30-2018, 04:58 PM
I had my car soda blast with great metal surface results. You can do nothing about a year without treatment if inside. I wash mine and then wash it with metal prepped and then epoxy primed it. As most project, still in epoxy primer in good condition. I have a friend in the business Nu-Tech Refinishing that did mine. he does service at his location and in the field. he sale the equipment too. check his web site out at www.nutechsodablasting.com . He warn me about the warping with a lot of the system out there. Give Lanny a call I'm sure he will guide you to a good solution.
Tim
dhutton
09-01-2020, 05:57 AM
I got my car lower part rust cleaning from sandblasting company (https://www.mandcsolutions.com/) and I'm satisfied with their services and the best part is that I don't have to take my vehicle anywhere as they provide doorstep services. If you need contact kindly PM me.
They don’t mention blasting cars on their website. Spammer?
Don
Samckitt
09-01-2020, 03:20 PM
How about blasting with dry ice?
https://youtu.be/usNv4XXMKfE
SPG
09-01-2020, 05:45 PM
Good luck being able to find someone that actually blasts with dry ice
TANKMASTERJ
09-05-2020, 08:49 PM
tankmasterj
Here, build thread Jason's 67 Camaro. I build, blast and. Paint water towers. I have blasted everything from house wood siding to steel tanks to car frames and bodies. The guy who said earlier in this thread Crushed glass is they way to go he is correct. And using. Water in blasting is fine while using hold tight 102 rust inhibitor mixed in while blasting. And power washing the entire surface when blasting is done with it helps as well.
