69-er
09-17-2015, 05:54 PM
This one's a puzzler...
I installed a Richmond gear set, (I know they're typically noisy), in a passenger Chevy 12 bolt and after 200 miles the rearend has become very noisy during coasting. Most of the driving has been around town below 45MPH. A few short, somewhat hard runs have been made under this speed, with easy shifts. At 200 miles, I took it on the highway at 60 MPH for 30 minutes two times. The first run in the morning I could hear a whine when coasting. The second run in the afternoon it became more of a howl than a whine. It's very "obnoxious", even over the loud exhaust.
The differential cover temp was 160 degrees after the second run. I used a magnet in the drain pan and found several metal bits, smaller than a grain of sand, more like a course grit. After letting the oil settle for a day I emptied the pan and fished some more in the "sludge". All that was on the magnet was very fine filings, which is what I would expect. No more bits of metal.
Richmond specifies the backlash at .010". I am getting very close to that with maybe .001"-.002" variation at three places on the ring gear. The carrier bearing races have a slightly frosted appearance.
On the gear patterns, the drive side is a little towards the top and close to the toe. It's somewhat of a thin pattern. The coast side is a wide pattern, maybe a little towards the top, centered between the toe and heel.
I guess the pattern could be just slightly deeper, but I can't understand why it's so noisy, I mean REAL noisy. I was wondering if the gears were going to make it home.
I've learned that coast/deceleration noises are related to the pinion. Before I removed the pinion the preload was at 15 in/lbs. with the seal installed and the carrier out. It had an ever so slight "rough" feeling, exactly like I would expect for bearings that are tightly adjusted. The pinion bearing races also have a frosted look but I can see a diagonal pattern. It's very smooth; I can't feel anything with my fingernail or knife blade edge.
Bottom line is that if this rear wasn't making noises and I was tearing into it just to inspect it, I would say everything is good. With noise I was getting I was expecting to see severe damage, especially with the small amount of metal bits I found.
WTH am I missing???!!!
Thanks!
Larry
Thanks!
Larry
