View Full Version : Looked up some part numbers and specs for Corvette brakes
MonzaRacer
09-13-2015, 06:45 PM
Front Rotors
#880408 GM Brake Code J56 ACDELCO 18A2807 {#88877686} Professional Durastop
# of Bolt Holes : 5
Bolt Circle Diameter : 4.75"
Brake Rotor Diameter : 13.97"
Brake Rotor Type : Disc Brake Rotor Only
Center Hole Diameter : 2.79"
Height : 1.78"
Mounting Type : Type K - Rotor Only. Wheel Studs Are Pressed Into The Hub Only. The Rotor Is A Loose Fit On The Hub & Is Retained By Either Machine Screws Or The Wheel Nuts. See Diagram For More Information.
Vented / Solid : Vented
Brake Rotor Discard Thickness : 1.18"
Brake Rotor Thickness New : 1.26"
Maximum Lateral Runout : .002"
#880334 GM Brake Code J55 ACDELCO 18A2429 {#19203421} Professional Durastop
# of Bolt Holes : 5
Brake Rotor Diameter : 13.38"
Height : 1.79"
#880253 GM Brake Code JL9 ACDELCO 18A2308 {#19175920, 19286286} Professional Durastop
# of Bolt Holes : 5
Brake Rotor Diameter : 12.79"
Height : 1.79"
Front Pads
UP8302M (six piston)
UP7599M
Rear Rotors
#880407 GM Brake Code J56 ACDELCO 18A2807 {#88877686} Professional Durastop
# of Bolt Holes : 5
Height : 1.93"
Brake Rotor Discard Thickness : .945"
Brake Rotor Thickness New : 1.024"
#880386 GM Brake Code J55 ACDELCO 18A2806 {#88877685} Professional Durastop
#880252 GM Brake Code JL9 ACDELCO 18A2333 {#19176757, 19286285} Professional Durastop
# of Bolt Holes : 5
Brake Rotor Diameter : 12.01"
Brake Rotor Type : Disc Brake Rotor Only-DIH Parking Brake
Height : 1.93"
Brake Rotor Discard Thickness : .95"
Brake Rotor Thickness New : 1.03"
Rear Pads
UP8303M (4 piston)
UP7600X
MonzaRacer
10-11-2015, 03:40 PM
The Z51 RPO was a just brake rotor size upgrade to the base corvette (C6 i believe). (EDIT: and a rear caliper variation, as per Apogee's post, #4 in this thread). (EDIT #2: Z51 is apparently a handling package, which includes the J55 brake RPO).
Base: JL9 brakes
Z51: J55 brakes
Z06: J56 brake
CALIPERS:
C#, RPO, Front/Rear # and size of pistons, Mfg, Colour
C5, Base, Front x2 40.5mm pistons, P.cast PBR, black
C5, Z06, Front x2 40.5mm pistons, P.cast PBR, red
C5, Base, Rear x1 45 mm piston, P.cast PBR, black
C5, Z06, Rear x1 45 mm piston, P.cast PBR, red
C6, Base, Front x2 40.5mm pistons, P.cast PBR, black
C6, Base, Rear X1 45mm piston, P.cast PBR
C6, Z51, Rear, X1 42.5mm pistons, P.cast PBR
C6, Z06, Front x6 33mm pistons, P.cast monoblock PBR, red
C6, Z06, Rear x4 30mm pistons, P.cast monoblock PBR, red
ROTORS:
C#, RPO, Diameter, Thickness, Pilot
C5(All)/C6, Base, Front 325mm x 32mm, 70.5mm
C5(All)/C6, Base, Rear 305mm x 26mm, 70.5mm
C6, Z51, Front 340mm x 32mm, 70.5mm
C6, Z51, Rear 330mm x 26mm, 70.5mm
C6, Z06, Front 355mm x 32mm, 70.5mm
C6, Z06 Rear 340mm x 26mm, 70.5mm
Notes
PBR is the Caliper Manufacture
The C6 front caliper is 20-30% more rigid then C5
C5 Red and Black Caliper are the same.
Chevy and Pontiac Hubs may have different offsets
Hubs and Axles will need to be turned down to 5.9" for the Rotors
