View Full Version : Better options for oem rag joint? 1st gen camaro
paulgurley
09-07-2015, 09:42 AM
Does anyone sell better options to replace the rag joint?
I am upgrading all of my steering with tru turn and a new quicker box, and I would like something a little stiffer than the oem rag joint
cactuss4
09-07-2015, 10:13 AM
Upper U-Joint: 1-48 x 1 DD (214352) Aluminum
Lower U-Joint for GC box: 1 x 3/4 DD x 3/4-30 (214931) Aluminum
Telescoping Shaft: 1 x 24" Extended Length (450024)
https://www.borgeson.com/xcart/home.php?cat=13
Talk to them , as I'm not sure what your needs are re the new box,but the above works with the common Grand Cherokee box.
I've not done this, but it's on my short list.
Tory
joejbal
09-07-2015, 05:11 PM
Check out speedway. I used their u joints a few years ago in a c-10.
lsa1stgen
06-28-2017, 08:57 AM
looking to replace my rag joint in a 68 camaro with a solid piece no rubber has anyone done this?
andrewb70
06-28-2017, 09:18 AM
What's wrong with a proper Burgeson or other u-joint?
lsa1stgen
06-28-2017, 10:38 AM
thats what i would like to do a u joint like that
a67
06-29-2017, 04:22 AM
Tried this on a 3rd gen, no go. It was always in a bind, as there is nothing to take up slight misalignment.
For a 1st gen there isn't much room for a u-joint as the box is behind the engine k-member. I used an aftermarket rag joint repair kit. The rubber piece was heavy duty replacement and stiff. So that worked out. Be sure to retain electrical continuity either through or around the rag joint, otherwise the horn won't work.
That is what the wire mesh is for on the OEM rag joint. I jumped around it with some regular stranded wire and ring terminals.
Bob.
