View Full Version : Stack ST 700 Display Tachometer
Cdog
09-06-2015, 01:55 PM
This is an awesome set up. I replaced it with a full AIM dash for my spec racer. In one gauge you have a Tach, lap timer, MPH, oil, water, temp & pressure, voltmeter, speed, recall, miles shift light and warning.
Stack ST700 Display Tachometer 0-8000 RPM Black face. $1300 set up. Sold!!! $550 Shipped!!!!
Tach, harness and timing beacon.
See link for details http://www.stackltd.com/st700.html
Stack ST546 Infrared Lap Timing Receiver and Beacon Assembly http://www.amazon.com/Stack-ST546-In.../dp/B008IZBQ84 (http://www.amazon.com/Stack-ST546-Infrared-Receiver-Assembly/dp/B008IZBQ84)
Stack ST918049 Sensor Wiring Harness for ST700 Integrated Race Dash http://www.amazon.com/Stack-ST918049...stack+ST918049 (http://www.amazon.com/Stack-ST918049-Sensor-Harness-Integrated/dp/B005JVNYDK/ref=sr_1_1?s=automotive&ie=UTF8&qid=1440447775&sr=1-1&keywords=stack+ST918049)
I can ship the Stack display tach. It’s boxed and ready to ship from my Scottsdale address. Pay via pay pal gift.
https://www.pro-touring.com/attachment.php?attachmentid=116938&stc=1
https://www.pro-touring.com/attachment.php?attachmentid=116939&stc=1
116940
116941
Cdog
09-08-2015, 08:31 AM
Bump for one of the best tach set ups out there. Make me an offer!!!
Cdog
09-14-2015, 10:54 AM
Ttt
Cdog
09-18-2015, 08:07 AM
Bump
Cdog
09-23-2015, 04:35 PM
Make me an offer..
Cdog
10-01-2015, 08:08 AM
Nobody?
Cdog
10-11-2015, 03:05 PM
Bump
Cdog
11-25-2015, 10:48 AM
Thanksgiving blow out price $550 shipped!
Cdog
11-27-2015, 08:02 AM
Bueller..........Bueller.......................Buu uuueller!
WTF! Where is everyone at? This is an awesome deal of a bitchin tach!
Cdog
11-28-2015, 08:45 AM
I’ve had some questions I thought I’d address. The tach comes with the needed add-on components to display speed, Tach recall, rotary switch to change display options & settings.
From site:
The ST700 combines the most critical facets of vaunted Stack Race Display into a tidy package, built with the same craftsmanship and attention to detail as the legendary original. With technology derived from decades of Formula experience, the Stack ST700 provides a comprehensive monitoring solution, displaying engine RPM, speed, system voltage, odometer, tripmeter, and acceleration timers (1/4 Mile and 0-60, and user selectable rolling speeds) as standard. An in-built sequential shift life and the ability to enable lap timing and two configurable inputs for either temperature or pressure via optional accessories gives the driver a remarkable amount of information in ever the tightest quarters.
Key Features
4 pattern Sequential Shift light
User configurable analogue channels
Peak Value Tell-Tales on all parameters
Supplied with mounting bracket, switch kit, separate professional wiring
Looms and manual included
Adjustable White LED back-lighting level
Fully sealed against water and dust
1 year competition warranty
For all negative earth ignition systems
Odometer and Trip Meter
Acceleration Timer (1/4 Mile, 0-60, user programmable rolling speeds)
Intelligent Alarm System
Intelligent alarms are provided on all monitored parameters. Alarm levels are adjustable to suit individual requirements.
Configurable Inputs
The ST700 system features two user configurable analogue channels. Each channel can be set up for Water Temperature, Oil Temperature, Air Temperature, Axle Temperature, Gear Temperature, Oil Pressure, Fuel pressure or Boost pressure.
Sensors must be ordered separately, choose between standard and solid state sensor options. These new optional sensors are small, lightweight, provide high accuracy and offer exceptionally reliability.
Display Features
Lap Timing System Lap Timing System
The lap timing receiver plugs into the standard dash wiring harness. When the vehicle passes the track side beacon the lap time "pops up" on the graphic display with an accuracy of 1/100th of a second.
Lap & Split Time Memory Lap & Split Time Memory
This feature records 75 Lap and Split Times (if Split Timing is activated) and helps drivers evaluate their consistency.
Speedometer Speedometer
The speedometer can be configured by the user for different tyre sizes and to display speed in either MPH or km/ h.
Performance Upgrade Performance Upgrade
The Performance upgrade consists of the Split Time system and the Straight and Corner Speed readout options. Whilst on track the split time features tells the driver of his time to reach two distance markers every lap, whilst the corner speed readout displays the minimum speed in each turn.
Cdog
11-30-2015, 08:06 AM
Bump!
Cdog
12-17-2015, 11:00 AM
Ready to ship!!
Cdog
12-22-2015, 11:06 AM
Sold!!
