View Full Version : Vaporworks tank pump wire size?
badazz81z28
09-06-2015, 07:45 AM
What ga wire do you all run to the 5th gen pump in the vaporworks? The harness Rick provides looks like 14-16 ga.
astroracer
09-07-2015, 04:41 AM
I would think 16ga would be plenty but it never hurts to do a plus 1 on the wire size if weight isn't a concern. If it's a long run 14ga would provide less resistance. A short run would be okay with 16.
Mark
CarlC
09-08-2015, 08:07 PM
Depends on the length of the wire run.
For most applications where the battery is in the trunk and a relay is used, 14ga is sufficient. If the battery is in the engine compartment then 12ga is appropriate.
The pump requires 11a at 13.5v/60psi, typical of most 5th-gen setups with an adapted regulator.
