View Full Version : Is it possible to replace an oilless compressor motor with one requiring oil,
cactuss4
09-01-2015, 09:32 AM
I have a big enough tank, but i'm tired of the oil less noise, so was thinking could I save the tank and install a oil required compressor motor in place of the oil less compressor motor?
To replace my entire unit I'm looking at maybe $700ish dollars, to replace the motor the head of it with a model that requires oil would cost under $200.00
Just wondering if it's do able.
Tory
Jetfixr320
09-21-2015, 12:10 PM
http://www.eatoncompressor.com/bare-pumps
Contact them. My Cambel Hausfield was on it's last leg. I got a pump from Poler air. And it has supplied air to paint 2 cars andshop tools for 3 years so far.
I know my compressor uses a oil type pump. But they can give you some info on if your motor is up to the task. You may have to modify the mounting pad and buy a new pulley.
MonzaRacer
10-30-2015, 07:32 PM
Most oil less are direct drive.
Since I have HF 2 doors down from work they have several oiled compressors. I also am looking at trying to make a direct drive motor run belt drive oil unit.
Auto Rod Technologies
11-03-2015, 05:46 AM
Best bet would be to buy a second compressor, and tie them together because then you will have extra tank storage, however that is not the cheapest route and may be overkill for what you are doing..
krom
03-13-2016, 07:12 AM
Awesome pumps!!
