View Full Version : Ditching built in audio system altogether
feeble
08-30-2015, 03:09 PM
When I get to the audio portion of my build, I'm strongly considering ditching built-in audio altogether and just using a roll bar mount bluetooth powered speaker system
Far from perfect sound I'm sure, but probably will be in the category of "good enough."
Anyone have experience with the golf cart, UTV or marine options?
For example: https://www.mtx.com/mud6spbt-universal-6-speaker-all-weather-sound-bar
andrewb70
08-31-2015, 04:36 PM
Shawn,
I think it is an excellent idea and should definitely be "good enough!"
I just did something similar and bought a Bravin bluetooth speaker for my Cougar.
https://www.pro-touring.com/~andrewb/cougar/657.jpg
It isn't permanently mounted, but sits nicely on the flat trans tunnel and is plenty loud. I like the MTX sound bar idea a lot. I'd figure out a way to mount it in the front as that will give you much better sound than from behind.
feeble
09-01-2015, 10:23 AM
Bluetooth speaker install looks great Andrew. I should be able to make something like that work easily in my pickup that is also without a radio but no way will it work in my Mustang. There is no under dash space that isn't designed for knees and feet and there is very little space between the dash and tunnel.
I'm not using the full console, but mine won't have much more room than this, a mostly stock Mustang II interior:
https://static1.pt-content.com/images/pt/2015/09/1978_00002_06-1.jpg
andrewb70
09-01-2015, 10:58 AM
I see what you mean. In that case, clamping it to the roll bar should work "good enough." The nice thing about the MTX sound bar is that it can be linked to an external amp. You might want to do this and run a small subwoofer somewhere. Like one of these guys:
http://www.jlaudio.com/car-audio-subwoofer-systems-microsub
I played around with a 6" version and it really boosted the bottom end, but keep in mind that most of that will get washed out when you go down the road.
feeble
09-01-2015, 12:43 PM
I'm just going to need a little part throttle noise to listen too. Full throttle, the car makes it owns music. :D
Thanks for the link, I'll check it out!
Cornbreadx
09-23-2015, 09:01 AM
Sony makes a deck that is operational from an app on your phone. It's an option - and you would be able to trunk mount it out of site and add in whatever speakers you wanted in any place that you desired. I am considering doing this as I don't really wish to cut up the 300 dash panel I purchased to put a deck in.
