View Full Version : 68-72 A Body 4L80 Crossmember
TheParker
08-24-2015, 06:19 AM
What are you guys/gals using? I'm looking for something with good clearance that is easy to take in and out. Ive read that some of the ones available have serious fitment issues.
Thank you
Sean Cooke
08-24-2015, 10:07 AM
Thank you
I used the stock one, all I had to do was slide it back for it to fit. I used one of the existing mounting holes & drilled a new one on each side. It was the simple and easiest way to eliminate all the issues I had been hearing about some of the aftermarket ones.
Typhoon1015
08-24-2015, 10:33 AM
I also moved the stock one back and drilled new holes. Any aftermarket one could be adjusted as well and I would anticipate it to fit without major modifications.
TheParker
08-25-2015, 09:20 AM
Did either of you have issues taking it in and out after modifying it? Im most concerned with how you have to slide it diagonally when removing.
Sean Cooke
08-25-2015, 09:43 AM
There is a section or plate on the frame close to where it mounts on both sides. I'm assuming your looking at this and wondering how it's going to work. I clearaced these sections so they are open. My car does have a roll cage, structural rigidity was not compromised. If you don't want to cut and weld in new ones. Mount the cross member below the frame, it's flat and probably won't hang much lower.
TheParker
08-25-2015, 10:47 AM
Ill box the frame in other places and move it on back. Thanks for all the input.
