View Full Version : LS Fuse Block
77tony
08-21-2015, 04:25 PM
Recently the main battery ground strap nut worked it's way loose and toasted the fan relay. Upon further review, determined that this ground fault surge also burnt the pin and plastic board behind the fan relay causing both fans to run full time (even with the AC compressor off). Looks like a new board fuse/relay board is in order. Does anyone have one for sale or know the part # for the fuse/relay board below ? TIA T
