View Full Version : Differential swap A body gm
keith4909
08-19-2015, 08:16 PM
How long does it take to swap a differential in an A body gm car? I'm putting in a 12 bolt and removing the 10 bolt. I'm just curious on how much time I should set aside. Don't include bleeding. I'm a mechanic by trade so my skill level is semi high. I haven't had the pleasure of doing one yet. Thank you
raustinss
08-20-2015, 05:22 AM
Super fast a easy ...2-3 hours when I did mine in a driveway with hand tools
andrewb70
08-20-2015, 06:20 AM
Four bolts on the control arms, two bolts for the shocks, the brake line, and it is out.
raustinss
08-20-2015, 08:15 AM
I didn't want to bleeding the brakes so I pulled the axles and removed the 4 bolt per backing plate....when it had drums
Andrew, don't forget he will probably have have driveshaft as well...4 more bolts.
keith4909
08-20-2015, 09:01 AM
Awesome. I have pretty wicked electric impacts. Glad to hear it's fast. One person should be able to handle it right. The axle I bought is complete from disc to disc. Just picked up a built 1965 chevelle 3.07 gear,posi, moser cover, all brake lines, and new disc for 1600.00. I'm so stoked. Perfect gear for my 474 Pontiac. All the doffs out here in California are 2k or higher for just the diff.
raustinss
08-20-2015, 10:29 AM
Yeah you shouldn't have a problem doing it yourself. A second set of hands never hurts though. As I said earlier I did it in my driveway on my back with hand tools so shouldn't be a issue for you
keith4909
11-23-2015, 07:10 PM
Got it in and you were right. Took about 2.5 hours. The diff fit great. I didn't even need to get new 1310/1330 u joint. The diff had the same joint as my 10 bolt. 3.07 posi with a 474ci roller. Now it just needs to be painted.
raustinss
11-23-2015, 09:00 PM
Nice glad to hear.
keith4909
11-27-2015, 09:27 PM
120092
