Ishmael
08-14-2015, 06:30 PM
For my 4l65 to shift I have to have 0 volts on the computer side of my brake switch wiring. I have 9.5. I have an aluminum LS2. My battery cables are tight. I have removed the paint under my grounds. I am using braided ground straps for all the grounds in the engine bay except to the battery. The battery is connected to the block and the frame and a smaller wire to the rad support. The engine has a ground to the computer, the frame in two places and the firewall. The firewall grounded to the frame. The rad support is also grounded to the frame.
My wiring harness is a classic update kit so it is new and has blade fuses. I disconnected the headlights - no change. I pulled each fuse in the fuse panel and the only one that changed 9 volts to zero was the brake lights but then the engine doesn't run at all but will obviously turn over. I cleaned up the sockets for the brake lights and the marker lights have ground clips (68 firebird). I pulled the tail lights right out - no change.
I don't have a ground from the alternator. Don't know if that is a good idea or not.
What do I have left? Any ideas to chase this down? Know of anything that would back feed 9.5 volts or is that just the amount that is back feeding?
Other than walking around the car talking to myself, what should I do?
thanks
Scott
thanks
Scott
