View Full Version : 6L80E G8 Trans Controller
67z28
08-10-2015, 07:14 AM
I need to find a stand alone controller for a 6L80E trans. The engine and trans came out of a 2008 G8 and they will be going in to a 69 Firebird. I have searched here on the site and on the internet also, but nothing seems clear. All the threads I find are old and I have looked at some of the aftermarket vendors and haven't had luck.
Any help would be great.
andrewb70
08-10-2015, 07:47 AM
Ray,
As far as I know, there is no such thing as a standalone controller for the 6L80E. The controllers are built into the transmission and will only work with OEM style engine controllers.
Barrrf
08-10-2015, 07:54 AM
Ray,
This.............but if youre swapping in both the engine and trans then why do you need a stand alone controller?
BonzoHansen
08-10-2015, 07:42 PM
I thought pcs made one, but i don't see it on their website. I know last time we went to sema they said they had or were going to have one.
67z28
08-12-2015, 04:59 AM
Thanks for the help. That's basically the same information I was able to find.
1989GTA
08-12-2015, 10:35 AM
Actually I looked into this recently and someone has come up with a stand alone controller for the 6L80 transmission. However if you have the engine and transmission out of the same car along with the E38 ECM, as stated why to you need a stand alone controller?
rustomatic
08-12-2015, 03:26 PM
Maybe someone's going carbureted . . .
Perhaps you could have someone (Speartech/PSI/some trans-specific shop) adapt/program a 4l80 controller to work on the 6l80 . . .
I'm also doing a 6l80 (or 90--still not sure/don't care) in my Falcon, but I'm using the 5.3's (Gen IV-2011) stock PCM and fuel system, which, if you do the wiring yourself, is hysterically cheaper than carburetion (and loads better in pretty much every way).
csouth
08-12-2015, 05:04 PM
Its not on their website, but its out there... I would Call PCS to see what's going on with it and check availability
http://zerogravityperformance.com/product/tcm-2600-transmission-controller/
84TXGN
08-12-2015, 07:15 PM
PCS will just direct you to Zero Gravity. I spoke with both a few weeks ago. Just call Zero Gravity and they will be able to answer you questions. As others have said, if you are running the G8 engine and trans you really shouldn't need it though.
Zapper
10-18-2015, 06:44 PM
Just to give you some insight, the 6Ls are nothing like the 4Ls
If you do not have the original body control module from the G8, you will have alot of difficulties getting it to run properly
The trans is electronically controlled and without the BCM telling it that its in Sport vs Manual, the trans will want to get into the highest gear as soon as possible
Im runnning a 6L90 with the PCS controller as well as the Shrifter Paddles and it was a mountain of work to get it running.
The PCS controller is just a glorified shifter and does not communicate with the transmissions TCU
No matter what you would need the TCU reprogrammed to accept Tap UP-Tap Down signals to get external paddles to work.
The aftermarket options are just not there yet, but SEMA is only like 2 weeks away so maybe that will change.
1989GTA
10-18-2015, 07:05 PM
I have a 1965 Buick Skylark with an L92/6L80. I do not have a BCM. I had both the E38 ECM and the T43 TCM reprogramed to the 2011 Corvette tune. No problems at all. I think I will add the paddle shift feature down the road.
Zapper
10-18-2015, 07:10 PM
The issues come around when you want to run the paddles. In auto mode it will drive like a normal automatic
