View Full Version : Door jam boots?
snappytravis
08-07-2015, 04:34 PM
I have a set of the electric life door jam boots. Just can't decide if I should go ahead and use them or go with a braided type. These are called the inclined model. Looks as the body and door holes would be offset aprox 3" or so. Just wonderind if I am on the right track or should I do something different.
I will have power window and lock and speakers to run. https://www.electric-life.com/product/4301-70-011-58-diameter-flexible-inclined-rubber-tuber/
Spork82
08-07-2015, 05:38 PM
I installed those boots, they seal really nice and with that bend you get ample strain relief.
They look stock and have lots of room to run wire. I would pass all your wires through before snapping the boot into the hole, almost impossible to fish wire through after that.
I did power windows and power locks.
snappytravis
08-07-2015, 09:35 PM
It looks like they would go with one side lower then the other.. or do the holes go straight across like the factory ones would? thanks for the input.
parsonsj
08-08-2015, 05:18 AM
Right: they don't use the factory holes or dimples. Use the factory location in the cowl/a-pillar, and go lower on the door.
snappytravis
08-08-2015, 08:20 PM
Thanks John, I just didn't want to do something wrong,, then have to have a talk with myself! That happens quite often.. thanks again
