View Full Version : ridetech 4link install 1969 camaro
sean69cam
08-01-2015, 03:43 PM
Installing ridetech 4 link in my 69 camaro and can't seem to center the reared within the wheel well. To get it to center the pinion angle is up 3 degrees. I am trying to have pinion angle down 2-3. I am including a picture with pinion at 0 and not centered in the wheel well. I have the poly bushing for the lower link and wondering if should go to heim link to adjust the length to help centering. As i am taking a break i was thinking a shim at lower axle mount could help with pinion angle
any thoughts? I would appreciate help if others have gone through this
https://static1.pt-content.com/images/pt/2015/08/image-1.jpg (http://https://static1.pt-content.com/images/pt/2015/08/image-1.jpg)
http://https://static1.pt-content.com/images/pt/2015/08/image-1.jpg (http://s1187.photobucket.com/user/sean69cam/media/Mobile%20Uploads/image.jpg.html)
Thttps://www.pro-touring.com/newthread.php?do=postthread&f=21
nats68
08-01-2015, 04:24 PM
I have the same problem with my 68.
I called ridetech and they said it's normal. I looked at a bunch of pics online at cars with the ridetech 4 link and most are that way.
I don't notice it anymore and it doesn't hurt the performance, from what I can tell.
I tried to center mine but realized it would be a real pain in the ass.
Here's a pic. Rear wheels are 18x10 with 275-40/18. Just to give you an idea what you're looking at.
115685
dhutton
08-01-2015, 05:14 PM
Not sure why you want the pinion down but I used pinion shims to center the wheels with my G-Bar. Don't get too carried away though because they will also lower the ride height and throw off your shock travel centering.
Don
sean69cam
08-01-2015, 05:29 PM
my engine is 3degrees down so I was thinking to keep drivetrain angle good to avoid vibration the axle should be 0-3 degrees down. Is that correct thinking?
Schwartz Performance
08-01-2015, 05:58 PM
Nope.. Your pinion needs to be opposite aka parallel with your trans output shaft. So up is correct.
-Dale
not the end all be all but the graphic will help
https://static1.pt-content.com/images/pt/2015/08/1280driveshaft_angles_zpsnddxwazh-1.jpg
sean69cam
08-02-2015, 06:49 AM
I see now, thank you. I wasn't thinking right. Thought adjusting angle down allowed for pinion to come up when accelerating and then parallel.
Carl @ Chassisworks
08-03-2015, 01:12 PM
That is correct. When you are on the gas the pinion rises a few degrees. How much varies based on suspension type, horsepower, and other factors. If your engine is down 3 degrees then you would set the pinion at 2-3 degrees down FROM PARALLEL. Parallel is 3 up. Therefore, the pinion should measure 0-1 degree up when the car is sitting static.
That will allow the u-joints to be come into phase and reduce driveline vibration and parasitic drag.
