View Full Version : installing steering column
thumper877
07-25-2015, 04:34 PM
I have a 69 camaro. When we did all the metal work we also did a smooth firewall. My question is how do I go about figuring out where to drill the hole in the firewall. I'm installing a flaming river column. Any help appreciated thanks
Schwartz Performance
07-25-2015, 04:38 PM
Bolting it to the dash or holding it up should give you an idea.. Or use a shorter 2" pipe to do that..?
-Dale
gbledsoe3
07-25-2015, 05:01 PM
Thanks I will be doing the same in the coming weeks.
thumper877
07-25-2015, 05:11 PM
The only thing I have on the inside of my interior is the two bolts coming down from upper cowl don't have a dash in it do I just bolt it two those bolts
Build-It-Break-It
07-25-2015, 06:02 PM
What I did was I bought a short 2" piece of 3 ft pvc pipe from the orange hardware store and zip tied that to the steering column mount. Then bolted that to the dash. Mark around the area were the pipe touches to give you the general area of were to drill. Get the 2" hole saw and trace the back of it into the area marked and cut it out. I've used this method on my car and a few of my other cars.
