View Full Version : Correct adapter size and where to get them?
spitfire980
07-25-2015, 09:56 AM
Hi guys
I have a 69 Chevelle and i got a great deal on American racing wheels and tires and unfortunately they don't fit at all!
So im in need of adapters but i need recommendations on where to get them and what size?
Front: 17X9.5 rim
Front backspacing: 5 inches
Front tire: 275x40xZR17 Nitto NT555
Rear: 17x11.5 rim
Rear Backspacing: 7.75 inches
Rear tires: 315x35xR17 Nitto NT555R
Any help would be appreciated!
spitfire980
07-25-2015, 08:47 PM
Found the adapters, i just need sizes now:
http://www.ezaccessory.com/Wheel_Adapter_5_Lug_4_75_To_5_Lug_4_75_p/5475-5475c.htm
TheJDMan
07-26-2015, 08:34 AM
I don't think anyone can tell you what size adapters you need with any accuracy. I suspect you are just going to have to mock the wheels up under the car and start measuring.
spitfire980
07-26-2015, 11:09 PM
I was checking the American racing website and no where have i been able to find a 11.5" torq thrust rims. Did some research and the largest they came on was 11". I guess the seller measured it from outer edge to outer edge.
The rims are American Racing VN505.
According to these posts, the rear backspacing needs to be 6.25" and i mocked the wheels and estimated will need a 1.5" adapter.
http://www.chevelles.com/forums/showpost.php?p=239090&postcount=16
http://www.chevelles.com/forums/showpost.php?p=710902&postcount=121
http://www.chevelles.com/forums/showpost.php?p=1661293&postcount=244
For the front, the rim mounts perfectly but it rubs against the upper control arm and when turning the wheel, it hits against the hotchkis sway bar
