View Full Version : 69 performance truck
Pooles Mill Rods
07-21-2015, 07:46 AM
I purchased purchased this cab and chassis in late October 14 with intentions of building a fun driving truck that I could hit some autocross courses later this year . Chassis is boxed and x braced In certain areas, ridetech front coilovers, healthy ls6 and t56. https://static1.pt-content.com/images/pt/2015/07/20141015_175643-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/20141015_175643.jpg.html)https://static1.pt-content.com/images/pt/2015/07/20141119_210508-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/20141119_210508.jpg.html)https://static1.pt-content.com/images/pt/2015/07/20150622_194845-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/20150622_194845.jpg.html)https://static1.pt-content.com/images/pt/2015/07/20150621_194212-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/20150621_194212.jpg.html)https://static1.pt-content.com/images/pt/2015/07/20150704_171314-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/20150704_171314.jpg.html)
chevymike
07-21-2015, 01:02 PM
Looking great. Should be a fun ride!
68byrd
07-22-2015, 01:06 PM
Looks like you have a really good start. What are you running for EFI managment and throttle body?
protouring70
07-22-2015, 01:27 PM
Great start!
cactuss4
07-22-2015, 01:50 PM
love it!
Pooles Mill Rods
07-22-2015, 05:52 PM
Thanks guys. The efi is a stock gm harness heavily reworked and a stock throttle body that I made an intake adapter for and machined a press fit adapter for the the throttle body to accept the carbed style air cleaner.https://static1.pt-content.com/images/pt/2015/07/20150102_2025021-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/20150102_202502-1.jpg.html)https://static1.pt-content.com/images/pt/2015/07/20141223_1639121-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/20141223_163912-1.jpg.html)
68byrd
07-22-2015, 07:24 PM
Wow, nice work. I take it you will be switching to speed density? Also, is that the Holley mid rise intake? Sorry to bother you will all the questions.
68byrd
07-22-2015, 07:26 PM
Damn it, another question. What accessory belt drive are you running? I really like the low mount alt and a/c compressor. Thanks
Pooles Mill Rods
07-23-2015, 03:25 AM
Yes, I will be running a speed density tune. The belt drive is 4th gen fbody with a cbm power steering bracket and the a/c compressor is an sanden 508 with home made brackets. The intake is a holley single plane drilled for efi.
Justin@EntropyRad
07-23-2015, 09:00 AM
Diggin' that setup, and like the tubular bracing on there!
If you need help keeping it cool, LMK!
Pooles Mill Rods
12-23-2015, 03:01 PM
Fast forward, I managed to get the truck up to Good Guys Charlotte and Autocross all weekend. The truck did great despite loping a power steering pump Saturday morning and tearing up the sway bar end links on the front several times. All in all I had a blast and manage to put about 500 miles on it since. https://static1.pt-content.com/images/pt/2015/12/20151017_164027-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/20151017_164027.jpg.html)https://static1.pt-content.com/images/pt/2015/12/IMG_20151026_195038-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/IMG_20151026_195038.jpg.html)https://static1.pt-content.com/images/pt/2015/12/IMG_20151109_193037-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/IMG_20151109_193037.jpg.html)https://static1.pt-content.com/images/pt/2015/12/20151115_144222-1.jpg (http://s803.photobucket.com/user/dkauffman05/media/Mobile%20Uploads/20151115_144222.jpg.html)
Slick68
12-23-2015, 05:25 PM
What's the specs on the wheels/tires?
Pooles Mill Rods
12-23-2015, 05:48 PM
Wheels are all 4 18x9.5 front 5.5 bs and rear 5.0 bs. Tires are 295-40-18
68Formula
12-23-2015, 07:32 PM
Wow, that's a lot of meat. Any mods required to fit? Love the truck.
Pooles Mill Rods
12-23-2015, 07:46 PM
No body mods , I might raise t h e front up a bit or look into fabing some new front inner fenders. The front tires rub a bit in hard cornering .
Slick68
12-24-2015, 06:13 AM
OK, Thanks. I was planning to run a similar setup. I was going to try 5" bs in the front. Where do the fronts rub?
Pooles Mill Rods
12-24-2015, 06:55 AM
They rub on the very outside of the tire about 1" after the inner fender begins.
Clutch93
12-24-2015, 10:06 AM
Awesome looking truck! It's so clean and simple yet so cool looking! What color is that? It looks like the satin silver from BMW.
Pooles Mill Rods
12-24-2015, 10:11 AM
Thanks. It is a bmw color called frozen gray.
Steve-O-08
12-24-2015, 10:46 AM
The truck looks great. The stance with that wheel and tire look perfect. Really dig the intake setup with the stock throttle body. Nicely done.
Slick68
12-24-2015, 02:26 PM
That counts out going with the 5" backspace, then. lol
AutoX_D21Hardbody
01-22-2016, 02:34 PM
Truck looks great! Autocrossing trucks rule!
flomofo
01-22-2016, 06:01 PM
Hope you do well, color is great.
