View Full Version : wilwood proportion valve under master cylinder
icemanrd19
07-17-2015, 07:58 PM
Im running into issues with my proportion valve. Its actually touching my inner fender and I'm not comfortable with the room to route my brake lines to it. I noticed art morrison has this kit but it sounds like they won't just sell the bracket and lines. Anyone else run into this issue
http://www.artmorrison.com/uploads/wilwood-225.jpg
cactuss4
07-17-2015, 08:35 PM
Tobin stated that willwood just came out with a prop valve bracket that sits on the inside toward's the engine will that help?
Tory
icemanrd19
07-24-2015, 08:32 PM
This is what I'm looking for by art morrison. Hoping they just sell the bracket and hardline. https://static1.pt-content.com/images/pt/2015/07/wilwood225-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/wilwood-225.jpg.html)
cactuss4
07-24-2015, 08:36 PM
Oh ya that would have been nice on mine as well.. Let me/us know if you find it, that seems like a great fit. My mount is not bad but its touching the inner fender. that would tuck it up nice and tidy!
Tory
gray86hach
07-25-2015, 07:16 AM
I cut a slit in mine and adjusted the inner till it cleared and welded a patch in it
Tim
icemanrd19
07-25-2015, 02:36 PM
i need all the tire clearance that i can. This bracket and lines is much simpler. If they won't sell it to me ill just make them
sjaroslo
07-25-2015, 08:56 PM
It's been a while now but Art Morrison did sell me just the bracket, lines and valve. BUT, I don't see a part number for just that in their catalog, so.... Hope that it works out.
Interceptor5588
07-26-2015, 07:31 AM
http://www.wilwood.com/MasterCylinders/MasterCylinderKits.aspx
icemanrd19
07-26-2015, 07:55 AM
Thought about the mustang kit which moves it to the other side. Art morrison version is by far the best
WallaceMFG
07-27-2015, 06:29 AM
I built one myself for the Chevelle. The bracket wasn't hard, but the lines were a little tricky. The prop valve sticks up at an angle so it's easy to reach the adjustment knob and has plenty of clearance to the inner fender.
https://static1.pt-content.com/images/pt/2015/07/P1010862_zpsb5db5110-1.jpg (http://s44.photobucket.com/user/hondaman117/media/P1010862_zpsb5db5110.jpg.html)
icemanrd19
07-27-2015, 02:24 PM
art morrison sells a complete kit for $135. Wilwood valve, bracket, hardware and lines for $135. I ordered just the bracket and line kit for $60. Should be here fri if not early next week and i will install it. Will update once i get the kit
icemanrd19
08-03-2015, 06:52 PM
The fit is clearance is perfect. I will suggest this bracket kit every time from here on out. I will get a pic later this week
