View Full Version : Moser 12 Bolt for Ridetech 4 Link?
Smoker03
07-13-2015, 05:32 PM
I left a couple messages with Moser today, and it was to late to call Ridetech when I had a free moment. Does anyone know if Moser sells a 12 Bolt with all the brackets welded to the housing for the Ridetech 4 link on a 1st Gen Camaro? I know that is what the 48 Camaro is running. Any info would be great. Hopefully I'll have some time to call Ridetech tomorrow. If I get an answer I'll post the info for future.
MadGoat
07-13-2015, 05:45 PM
For all.... they do not do this anymore.
bret
07-14-2015, 02:59 AM
The best way is to order it with the leafspring pads in the oem location then bolt our lower brackets to them. The upper 4 link tabs will need to be positioned and welded with the rearend in the car at ride height and pinion angle set correctly.
The wide variety of drivetrain position combinations makes it very troublesome to offer a prewelded rearend.
Smoker03
07-14-2015, 09:01 AM
Thanks for the info. I have an original 12 bolt, but since I am mini tubing the car I also wanted to narrow the rear end but the factory spring perches don't allow much room to narrow the housing. I may end up purchasing the lower weld on mounts which should give some more room to narrow the housing.
bret
07-14-2015, 03:10 PM
Excellent choice!
