View Full Version : Ls motor mounts that dont vibrate
eric1967
07-13-2015, 12:07 PM
Are any of you using a Ls motor mount that do not vibrate when you are driving? I have Energy Suspension polyurethane mounts, but I get engine harmonics when driving about 70mph. I believe Stielow uses 4th gen Camaro mounts for this reason, but I don't think they will clear my headers. I am looking at the Chris Alston Chassisworks mounts. Does anybody have any experience with those? Here is a link.https://www.cachassisworks.com/p-1122-camaro-67-69-nova-68-74-billet-motor-mount-and-frame-adapter-set-ls-engines.aspx
Thanks Eric
Bad94
07-13-2015, 02:34 PM
I have solid mounts in mine, car is smooth going down highway.
How much does the motor move when you rev it sitting still?
Sure you don't have a motor ready to come apart? Or tire not balanced? Driveshaft?
dontlifttoshift
07-13-2015, 02:46 PM
Eric, the alston mounts will be worse. Are you using an energy trans mount, too. Change the trans mount to rubber if you can, that will cure most of it.
Dan is right, make sure it is RPM related and not speed related. At 70 mph, downshift and maintain speed see if it changes.
eric1967
It is smooth with rubber mounts but they don't last. It's not really a vibration as much as harmonics. Motor is not moving much. You can feel it just bring the motor up to cruising rpm while parked.
eric1967
07-13-2015, 02:55 PM
I will try a rubber transmission mount. Dan what mounts are you using? Thanks for the help. I think some of it is I am getting older & just want things smoother & not as loud
parsonsj
07-13-2015, 03:20 PM
Holley/Hooker makes a whole set of motor mount adapters. I swapped a customer's car from polyurethane to OEM rubber mounts using the Hooker setup. It made the car a lot more docile. I kinda missed the "tautness" but the customer loved the softer feel.
Bad94
07-13-2015, 06:20 PM
We made our own mounts. We pushed the motor down and far back as we could.
eric1967
07-18-2015, 07:55 AM
Donny the rubber trans mount helped with the harmonics. It probably cut in half maybe even a little better than that. Thanks for the help.
andrewb70
07-18-2015, 08:21 AM
For my Cougar LS swap I used the 4th gen F-body mounts and the stock rubber trans mount. There is definitely a harmonic present that is at a much lower frequency than engine or driveshaft speed and the rubber mounts do a great job of isolating them.
meenaggie
07-18-2015, 09:00 AM
My builder likes the BRP LS motor mounts. They replace the frame stands and don't require the use of the original SBC motor mounts. They come standard with poly bushings but they offer solid bushings as well. Might be worth a try. And no, I am not using them as I had the LS2 located before I took it to my builder.
115192
T_Raven
07-18-2015, 06:13 PM
I've got solid mounts on the LS1 in my 89 GTA with a poly trans mount. I actually really like it. When my clutch was new and would chatter when starting from a stop, it was really annoying, but after the break in period that got a lot better.
I wonder if there are other causes being made more noticeable by the stiff poly mounts vs the rubber ones absorbing the vibrations.
parsonsj
07-19-2015, 09:52 AM
My builder likes the BRP LS motor mountsThose are the very ones I replaced. The Hooker/Holley setup is much better, and the pricing is about the same.
eldogg
08-15-2015, 07:14 AM
We use Prothane mounts at DSE. No vibrations at all. I would look at your drive line angle. If the vibration was in the mount it would vibrate at same RPM no matter of vehicle speed. I hope this helps.
Eric Evans
PhillipM
03-17-2016, 12:21 PM
Old thread, but John do you have a link to the ones you're speaking of?
parsonsj
03-17-2016, 12:30 PM
Sure!
I'd start here: https://www.holley.com/products/ls_power/engine_and_transmission_mounts/ls_engine_mounts/
Member Toddoky here is a Holley engineer and knows these mounts better than anyone. I've found him real responsive to PMs...
PhillipM
03-17-2016, 03:12 PM
I now see what you mean. Those mounts use stock 4th gen isolaters. They don't list them for 64-67 A bodies. I'm sure they could be made to work though.
andrewb70
03-17-2016, 03:57 PM
Phillip,
Todd is working on the 64-67 A-bodies as we speak. The Holley kit uses the same 4th gen f-body mounts that I used in my Cougar.
http://ls1tech.com/forums/conversions-hybrids/1823793-hooker-1964-67-body-ls-swap-system-preview-thread.html
PhillipM
04-05-2016, 02:40 PM
Cool thanks Andrew!
badazz81z28
04-05-2016, 06:10 PM
Prothane here too, no issues. I also agree to check the driveline angle
