View Full Version : to go bbc or sbc?
bbcmonte
07-11-2015, 01:56 PM
iam building a low budget protouring street car.it is a 1970 monte.I was planning to go with a 496 bbc stroker,but I can get a 400 sbc block.i was wondering if it I should build a lighter 421 sbc stoker since I plan to inpove the handling of the big monte.
TheJDMan
07-11-2015, 05:48 PM
IMO, the SBC would be my choice due to the weight difference. You will be facing a challenge getting that car to handle well without the additional weight handicap of the BBC. HP out of the 421 should be more than sufficient to have fun.
fun2run
07-12-2015, 05:58 AM
You will never be winning any autocross with that heavy of a car. Go BBC and have fun cruising with a car that has good handling, brakes and occasionally on the twisties. My .02. More torque for acceleration.
bbcmonte
07-12-2015, 08:59 AM
I really don't plan to autocross,but don't weight much more then a chevelle or most a bodys.
WallaceMFG
07-12-2015, 01:39 PM
Pick whichever one you think you will enjoy more. If you want more handling performance, choose the small block. If you just want to have fun and not care about lap times, get the big block. Nothing sounds quite as good as a big cube motor at idle haha
fun2run
07-12-2015, 03:11 PM
FWIW... I am redoing a ZZ572 for 850+ HP on pump gas. Sure it will be nose heavy but yes my car will still handle and brake well. Gonna have some fun for awhile then someday transplant a blown LS or ??? Will take the BBC and put in a Chevelle probably.
bbcmonte
07-13-2015, 06:16 PM
I am going stay big block
MonzaRacer
07-27-2015, 03:55 PM
Big block with aluminum heads, accessories, headers.
Then it will run as well as a Chevelle. I would slap on some air ride, and enjoy.
chpr1972
08-10-2015, 06:12 PM
BBC if you want LOW end torque that sets you back in the seat. SBC if you want high winding horse power. Yes I DO run a BBC and recently bored and stroked it to 496 [.060 over bore and a 1/4' stroker] I also went with a hydraulic conversion roller mild at 230/236 at 515/ 520 lift Comp Cam. I have closed chambered iron head that are ported to the max with big valves. HP with a 750 carb and torker intake hood clearance] putting out a mild 500 525 hp. If you go BBC and running a carb make sure it has a mechanical fuel pump boss. Do not run an electric fuel pump unless you have to. Just my 2 cents
chpr1972
08-10-2015, 06:14 PM
I would not go with air ride until you check with your insurance co. I recently was checking on insurance and the most ask 1st question was DO YOU HAVE HYDRAULICS OR AIR RIDE
Sean Cooke
08-14-2015, 07:08 AM
Bbc is alot of fun on the street, I have 496ci with aluminum heads, easy way to make 600+ hp when your on a budget ... SBC's make plenty of power with the right parts.
Kcorrigan2
08-14-2015, 08:11 AM
Having had both in a Monte I would suggest the small block. In fact I would go get one out of a late 1990's era truck...hydraulic roller, Vortec LT, Gen II...however you want to refer to it. You can build that engine for peanuts, over 400 hp easy and all day long...plenty to move your Monte around nicely, lighter, cheaper, quicker...you can even drop in a brand new 350 Ramjet, 400 ft lbs, fuel injected for around $5,000.
Big blocks are beasts, no doubt. But they are heavy, expensive beasts. So many small block choices. 5.3l LS out of a truck...430 hp, can be had running for a few thousand with everything you need to install.
My two cents
Rod
08-14-2015, 08:29 AM
i am building a low budget protouring street car.
this right here!....^^^^^^^^^^
price out the engine mods wanted for both SBC and BBC,,,I mean everything, valve covers, pulleys, engine mounts, bolt sets ....every part and the go to your local auto parts store and ask them whats on the shelf for each.... what ever motor choice they have to order more parts for is the one I would not install...because when your at and event 700 miles from home and you need a part to get home, (this is a low buck so you wont have a sh*t ton of parts your dragging with you) you need it then not 2 days from then....
