View Full Version : 66 Chevelle throttle pedal options
cactuss4
07-08-2015, 02:30 PM
So on my maiden drive today (and I got my plates!!), so I can drive it.. (reminder to those in CA, put the car in non OPP, I had to pay $1000 for 3 years of registration, even though the car never left the garage, BAHH!!)..
So on my maiden voyage the throttle pedal moved off the throttle rod and I had well very limited throttle (oh **** moment). So I was wondering if there is a good 3 piece pedal assembly that would make more sense to swap to (without a ton of modifications), or am I better off just doing something like the Lokar Throttle pedal?
Obviously for right now I just need a throttle pedal that will be there when I need it (always), but the future I would like to have my pedals more aligned and wondered if I could get rid of the floor mount throttle or not.
Just looking for some ideas. And ya I'll be doing a motor/6spd at some point , so maybe then would be the right time to consider swapping out all my pedals since the 4spd one with the solid rod is not going to work.
tory
cactuss4
07-08-2015, 08:03 PM
I've been doing more reading as I tend to post the question and then go off looking for an answer (kind of bassackwards eh)..
So it appears I can do a 6cylinder Camaro pedal (or something from a 66-67 GTO), and then grab a lokar cable setup and it bolts to the stock location etc. I'm going to try this avenue for a quick fix and wait for major reconstruction to change it to something else. Just need something that is not going to flop all over (I think my issue is I have an aftermarket cover, but it is not actually mounted or held to the rod.)..
tory
analyte
07-09-2015, 02:59 AM
Prior to my LS swap, I was using a gas pedal from a early Nova I believe when I swapped to a cable setup from the original throttle rod. It worked great, fit in stock location and used a 70 Chevelle throttle cable I believe.
I still have the pedal so I'll hunt it down and get you a pic if needed.
Kerry
cactuss4
07-22-2015, 01:02 PM
Thanks I bought the 6cylinder pedal and swapped to a throttle cable vs the rod. Pretty slick and makes things nice and clean. Must more responsive throttle now.
Tory
Jmcc214
07-29-2015, 01:34 PM
What year 6 cylinder pedal did you get ??
cactuss4
07-29-2015, 05:14 PM
K1520 67-69 CAMARO ACCL PEDAL ASSY
classicindustries.com
