View Full Version : Need a little advice on gauges? Holley Digital Dash?
snappytravis
07-05-2015, 02:57 PM
I am working on a 69 Camaro ls3 supercharged with a holley hp ecu. I purchased the holley digital dash to run for gauges. I have two ideas I am considering.
1. Order a anvil blank dash or dse and mount the holley hp dash to it similar to how racepak gauge panels are mounted. Then install a classic custom truck console and mount stereo into the console.
2. Order a speedo and tach and install in dse or similar gauge panel and install the holley digital dash in the console where the stereo would have been and do something different with stereo. I like the idea of the holley setup being compatible with the holley hp ecu. It seems to be pretty simple install and I can do everything I would like to do.
I would like to monitor the following items.
Speedo,Tach, A.F. Ratio, Oil Pressure, Oil Temp, Boost, Battery Voltage, Coolant Temp, Fuel Pressure.
Please tell me if I am going in the wrong direction..
Thanks Travis
