View Full Version : New Chassisworks Torque Arm Rear Suspension
Carl @ Chassisworks
06-30-2015, 09:43 AM
Chassisworks is excited to announce the latest addition to our complete line of Pro-Touring suspension systems - The Chassisworks Torque Arm g-Link.
Click To Enlarge
https://static1.pt-content.com/images/pt/2015/06/5857F2102_assemblyfront_at-1.jpg (https://www.cachassisworks.com/site_images/58XX/5857-XXX/5857-F21-02/5857-F21-02_assembly-front_PRKR.jpg)
A skillfully engineered system with multiple geometry and setting adjustments for tuning and refinement, Chassisworks' Torque Arm g-Link Suspension directly replaces the OEM leaf springs and shocks for significant performance increases in cornering ability, throttle response, and braking stability. System packages include our unique fabricated torque arm, g-Link tubular-steel pivotball lower arms, a Watts link or panhard bar lateral locator, VariShock billet-aluminum coil-overs, weld-on frame brackets, and optional billet-arm splined-end anti-roll bar.
The torque arm requires a Ford 9” center section and Chassisworks Subframe g-Connector chassis stiffening system or universal-fit tubular crossmember. Weld-on lower axle brackets are included with bolt-on brackets for GM multi-leaf spring pads as an available option. Applications include ’67-81 Camaro/Firebird and ’62-72 Chevy II/Nova with OEM wheel tubs or mini-tub conversions. There are also components available for custom-fit applications.
Click Here (https://www.cachassisworks.com/c-313-suspension-rear-pro-touring.aspx)to view available options and configure a system for your vehicle or call direct to 800-722-2269.
For an extremely detailed and thorough review of all aspects of this system, I encourage you to download the 20 page Product Data Sheet by Clicking Here. (https://www.cachassisworks.com/Attachments/DataSheets/5857-XXX_DS_WEB.pdf)
Click To Enlarge
https://static1.pt-content.com/images/pt/2015/06/5857F2102_5926F21_front_at-1.jpg ( https://www.cachassisworks.com/site_images/58XX/5857-XXX/5857-F21-02/5857-F21-02_5926-F21_front_prkr.jpg )
cduke1780
06-30-2015, 06:57 PM
Any chance to make a torque arm set up for a 64-67 A body chassis? I would love for my 66 skylark to have this. A full aftermarket frame is outta the question budget wise.
Caleb
mean buzzen half dozen
06-30-2015, 08:31 PM
Your 66 Skylark already has a nice 4 link that you can get great upgrades.
Carl @ Chassisworks
07-01-2015, 08:41 AM
Caleb
There is always a chance...
Plus, we offer some univseral options for those who want to get creative. CLICK HERE. (https://www.cachassisworks.com/c-1387-torque-arm-system-universal.aspx)
M4nt00th
07-01-2015, 11:26 AM
Any chance this will be made for the early Mustangs?
72BBSwinger
07-01-2015, 11:35 AM
How is ground clearance with 335's?
swain
07-01-2015, 01:47 PM
There we go. Nice work
Carl @ Chassisworks
07-01-2015, 01:59 PM
We actually already offer a torque arm system for the Mustangs as part of our Total Control Products line. It's a race proven piece and you can learn more at THIS LINK (http://www.cachassisworks.com/p-1881-mustang-64-70-cougar-67-70-rear-pushrod-coil-over-suspension.aspx).
Tire width doesn't effect ground clearance. This system will lower a car with stock floor a couple inches from stock.
Thanks!
Carl @ Chassisworks
07-01-2015, 02:03 PM
There are a lot of really cool features to this new system. To me, the torque arm itself is a work of art. It’s the same type of construction as our Camaro clips; fabricated box-tube construction comprised of laser cut panels with overlapping seams. This allows us to make it extremely strong and light without adding a lot of external bracing. We have been using this method for over ten years and, when paired with our in-house finite element analysis, it gives you a bulletproof end result.
Click To Enlarge
https://static1.pt-content.com/images/pt/2015/07/5857F2102_torquearmfront_AT-1.jpg (http://www.cachassisworks.com/site_images/58XX/5857-XXX/5857-F21-02/detail/5857-F21-02_torquearm-front_prkr.jpg)
The front torque arm connection, referred to as a ‘Sliding-Link,’ comes standard with a steel-sleeved poly bushing. A spherical pivotball is also available. Both versions feature a billet steel eye mount which is inserted in a greased bore in a billet receiver on the front of the torque arm. The bore is machined with a spiral, rifling pattern so that the link stays properly greased. A wiper seal keeps out road grime. There are more detailed pictures in the Product Data Sheet. Open the PDF by Clicking Here. (https://www.cachassisworks.com/Attachments/DataSheets/5857-XXX_DS_WEB.pdf)
Because not everyone has the same third member, there are two different pinion support mounts. The first will fit standard Ford 9” and Strange S-Series cases. The second is designed to fit the Strange HD-Pro aluminum case.
https://static1.pt-content.com/images/pt/2015/07/5857u0103_5_-1.jpg https://static1.pt-content.com/images/pt/2015/07/5857u0103_6_-1.jpg
Our gStreet Torque Arms use a serrated tab and washer mechanism to enable incremental pinion angle adjustment without the risk of slippage.
https://www.youtube.com/watch?v=FRNp7dp0XKM
A lateral adjustment mechanism below the rearend housing allows the torque arm to be perfectly aligned with the chassis bracket at the gConnector center support without affecting the wheelbase squareness.
https://www.youtube.com/watch?v=70rwM-U_mFU
BADNBLK
07-01-2015, 02:08 PM
Man that torque arm is nice! The "sliding link" design is really cool. You have any plans on offering this torque arm set up for 3rd & 4th gen Fbody? I hate my adjustable torque arm!
Carl @ Chassisworks
07-01-2015, 02:27 PM
You mean like this one (http://www.cachassisworks.com/c-1325-camaro-82-92-gm-f-body.aspx)? :)
We designed this one for drag racers but it has a similar sliding link at the front.
https://static1.pt-content.com/images/pt/2015/07/6294_1_-1.jpg (http://www.cachassisworks.com/popup.aspx?src=images/product/large/6294_1_.jpg)https://static1.pt-content.com/images/pt/2015/07/84f30e01_4_-1.jpg
BADNBLK
07-01-2015, 02:39 PM
Well.... I like how the new one mounts low off the 9", as my current, and looks like your drag set up would also beat the hell out of my floor and my ride height. Bookmarked anyway :) Thanks Carl!
Carl @ Chassisworks
07-01-2015, 02:52 PM
The tubular style above won't hit the floor unless you are REALLY low. Still, the new one is available as a universal kit and we make the arm in three different lengths. https://www.cachassisworks.com/c-1387-torque-arm-system-universal.aspx
72BBSwinger
07-01-2015, 02:57 PM
I was referring to a 26" tall tire like a 335, with that short of a tire how much ground clearance under torque arm and diff?
BADNBLK
07-01-2015, 03:13 PM
I guess I'm really low! lol I got some other fish to fry before I re-engineer what I got, but I really like the looks of the design. May still not work well with that specific design in my f-car, but looks like a killer set up for many others!
Twentyover
07-03-2015, 05:12 AM
Any love for 12 bolts? Or 9" the only flavor offered?
Carl @ Chassisworks
07-03-2015, 06:58 AM
Not much love here, but we know some people love them. :) The 12 bolt is coming, but it is a ways out at this point.
Carl @ Chassisworks
07-07-2015, 12:10 PM
I want to talk a little bit about the options for locating the rear laterally underneath the car. The torque arm system comes standard with a double-adjustable Panhard bar. A Watts link is optionally available and, so far, this is what everyone has chosen.
Click All Images To Enlarge
https://static1.pt-content.com/images/pt/2015/07/5857F2102_assemblyrear_at-1.jpg (https://www.cachassisworks.com/site_images/58XX/5857-XXX/5857-F21-02/5857-F21-02_assembly-rear_PRKR.jpg)
The Chassisworks Watts link is an incredibly stable piece of billet jewelry. The pivot assembly is made of our three main components; Base Plate, Watts Pivot, and Top Plate. The base plate is machined from billet aluminum and is mounted to the housing at four points. Four mounting positions for the Watts Pivot allow adjustment of the vehicle roll center to tune vehicle understeer/oversteer. The Watts pivot itself is billet steel and houses a sealed ball bearing. This makes it more durable on top of eliminating the stiction common with traditional bushing-style pivots. The top plate is laser-cut steel and bridges the Watts pivot with two additional stands and three fasteners which further eliminates side deflection.
Watts link pivot detail –
https://static1.pt-content.com/images/pt/2015/07/5857f2102_9_-1.jpg (https://www.cachassisworks.com/images/product/large/5857-f21-02_9_.jpg) https://static1.pt-content.com/images/pt/2015/07/5855u01_3_-1.jpg (https://www.cachassisworks.com/images/product/large/5855-u01_3_.jpg)
The chassis brackets are factory welded from laser-cut CNC bent steel and provide mounting for both the shock crossmember and the Watts linkage. The steel support tubes (shown in the first picture) are shipped loose. This is done for three reasons. First, it makes the packaging substantially smaller, reducing the cost to ship. Second, it allows a superior fit on a chassis that is inconsistent. And third, it allows you to customize the installation a bit to better cope with routing exhaust, etc.
Chassis bracket detail:
https://static1.pt-content.com/images/pt/2015/07/5857f2102_8_-1.jpg (https://www.cachassisworks.com/images/product/large/5857-f21-02_8_.jpg)
For more details or to find the system that fits your vehicle, follow THIS LINK. (https://www.cachassisworks.com/c-313-suspension-rear-pro-touring.aspx)
alcino
07-08-2015, 10:06 AM
Carl and Chassisworks,
Thank you for bringing out these cool products to help our old junk run better against the fresher Iron. I have an odd ball car (76 Mustang) so I was planning to modify one of your TCP Torque Arm units to fit. I was curious if there were reasons why these are designed differently (square tubing, mounting to pinion bearing, telescoping pivot) and why they are so much longer than the TCP mustang/cougar ones(33-36" vs 45-55"). I'm sure the design is because of packaging and possibly applying lessons learned or innovations. The difference in lengths seems to make the short ones favor acceleration and the longer ones braking(reduce wheel hop). That's theory from my readings so maybe in application its negligible and just easier packaging. Any comments?
Alcino Azevedo
Carl @ Chassisworks
07-14-2015, 12:03 PM
Alcino Azevedo
Hi Alcino, sorry I didn't see your post until today.
The length does in fact make a difference in practice and the shorter length of the TCP torque arms favor a stiffer sprung and valved suspension. The 33" and 36" arms were originally designed as part of our pushrod rear suspension, intended primarily for open-track/road-race use with a higher spring rate and reduced amount of suspension travel. This system has proven to be extremely effective and has excellent off-corner acceleration with the trade-off of being less street-friendly. Not to say that a large percentage of systems produced, didn't end up on very capable "street" cars.
The longer 45-55" arms are more forgiving under braking and can be used with softer sprung suspensions with greater range of travel; still very effective on track, but also largely acceptable for street use. Both approaches work extremely well, but I'd say the longer arm has a broader range of practical performance and might be better suited for your application.
72BBSwinger
07-14-2015, 01:38 PM
Can I get the watts mechanism separately?
Carl @ Chassisworks
07-14-2015, 01:48 PM
We offer a universal Watts link kit. You can find it at the link below. The mechanism is not available by itself.
https://www.cachassisworks.com/p-3187-universal-fit-billet-watts-link-50-max-width.aspx
Nothingface5384
09-22-2015, 01:29 PM
What length torque arm would you recommend for a 104 wheelbase ford maverick
Very similar to an early mustang..but different enough to beed longer LCA and reworkibg of everything
This universal kit may be the ticket
May do the same for my 72 skylark(112'wb) if speedtech cant supply a part list that ive been persistant about..
DudeTheCarMan
11-02-2018, 02:13 AM
Click To Enlarge
Click To Enlarge
https://static1.pt-content.com/images/pt/2015/06/5857F2102_5926F21_front_at-1.jpg (http://https://www.cachassisworks.com/site_images/58XX/5857-XXX/5857-F21-02/5857-F21-02_5926-F21_front_prkr.jpg)
So I have a 1968 Galaxie 500 fastback would this fit on the frame if I changed the rear axle
andrewb70
11-02-2018, 04:22 AM
Unfortunately, Carl is no longer at Chassisworks. Your best bet is to give them a call and ask.
TechGuy
11-02-2018, 10:57 AM
Actually , as long as you use a 9" style rear end, . we have kits that will weld into any car.
DudeTheCarMan
11-02-2018, 11:16 PM
what about front end its got an okay set but its just this stamped piece I want something a little better for her.
TechGuy
11-05-2018, 03:39 PM
a new front for the Galaxie ?.. if you can weld, I can get you started.. http://www.cachassisworks.com/p-3807-4x2-a-arm-front-frame-clip-6-clearance.aspx
Warthog5
06-05-2019, 02:40 PM
I know this is a old thread, but I seriously considered it.....Biggest draw back is no way to snake the exhaust piping thru it..
Not with Air Springs anyway.
SPG
09-23-2020, 11:59 AM
Has anyone actually installed this product? I can't find anyone who has
ilikeike
09-23-2020, 12:23 PM
I was looking at it myself, looks real nice, I like the front
bushing/bearing on the torque arm and the watts link setup too!
But shied away and went with the Speedtech since I never actually saw one in person at races or anyone on the forums.
Bobo73
04-15-2022, 08:50 PM
Here's a picture of mine (in a '73 Camaro). Exhaust is indeed tight and it's currently only 2" since I wanted something fast. I'm planning on eventually putting in a full 3" with an H-pipe and over the axle tailpipes.
199009
199010
SPG
05-18-2023, 10:16 PM
199009
199010
Hello, I bought a torque arm from chassisworks as well and I am hoping you can give me a lot of pictures and measurements of your set up so I can verify with what I have. Right now my torque arm extends 3" past where it's meant to and I am pretty sure some part somewhere I have was not made to spec
I am hoping you can reach out to me through private message so we can talk about this further, any help would be greatly appreciated since chassisworks is claiming I'm doing something wrong.
NCSU68
05-19-2023, 05:30 AM
If you have a question call Chassisworks directly. They have a tech team which is very good.
SPG
05-19-2023, 08:27 AM
I wish that was the case, their tech support is being incredibly unhelpful and refusing to acknowledge something is wrong. They keep blaming my issue on variations of the front subframe even though the front subframe doesn't change the install process of this kit.
My components are 3" off, thats not a variation issue, something was grossly miscalculated or I was given the wrong part.
NCSU68
05-19-2023, 01:39 PM
Try calling Carl Robinson at ChassisWorks 916 290 7612. He has helped me and fix several issues. I hope he can help you. Please post an update.
SPG
05-20-2023, 06:57 PM
Carl is the person telling me my issue is the differences in subframe causing problems sadly.
