View Full Version : Oilpan advice..
h_leadfoot
10-22-2005, 06:04 AM
..for my Camaro -68 SB.
Not for dragracing..
Henrik
CarlC
10-22-2005, 06:39 AM
Check my website
Gee, i think you gave us too much info, to make an educated guess. I'll second carls advice, his CV pan is pretty nice and moderatly priced. IF price isn't a concern milodon makes some nice road race pans
h_leadfoot
10-24-2005, 09:27 AM
Sorry for the lack of information..
It have to be for trackracing as well as streetracing not just for dragracing.
As much oilcapacaty as possible without interfeering with the rest of the stuff.
Were can I find the "CV-pan"? It looks nice.. Is it expensive?
B.R Henrik
chicane67
10-24-2005, 11:15 AM
You can either get the pan directly from CV or from the actual manufacturer who supplies this pan to CV.
CV Products:
CV 1080 LT (http://www.cvproducts.com/cv/products/specItem.aspx?prodID=1628&keyword=1080lt&brandID=18)
JR Manufacturing:
CP80LT-RR (http://www.champpans.com/wetsumpsbcv8.html)
Davezz28
10-27-2005, 01:01 PM
Moroso, Milodon, kevco, canton, & CV Products all make great pans.
The CV products pan is a great value, as it includes a louvered windage tray and it is priced right. If you go with the CV Products pan and are going to use it on the street and road racing, you might go with the CV1080LTRR pan. It has the same exterior dementions as the CV1080LT pan, but they add an additional trap door in the pan to gear it more towards road racing.
h_leadfoot
11-07-2005, 01:07 PM
I bought this one..
With Windage Tray, oil pump and pickup and on top of it all a Setrab oilcooler. Totall oilcapacity - 9,5Qts
- Small Block Chevy, Wet Sump -
https://static1.pt-content.com/images/noimg.gif (http://www.milodon.com/new%20images/31505.gif)
#31505
ROAD RACE
The hot tip for road racing due to trap door battle system proven to provide good oil supply on left and right turns. Proven highly effective in SCCA and other competition. Fits Corvettes, Camaros and most popular chassis.
Pan Capacity is 7 Qts. Plus Filter-
10" Sump Length, 75/8" Sump Depth
Left Hand Dipstick31505 https://static1.pt-content.com/images/pt/2005/11/addtocartsm-1.gif (http://www.abswebservices.net/Merchant2/merchant.mv?Screen=BASK&Store_Code=MILODON&Action=ADPR&Attributes=Yes&Product_Code=31505&Quantity=1)
Oil Pump and Pick-Up Required:
Milodon 18700, (Melling M99HV)18465 https://static1.pt-content.com/images/pt/2005/11/addtocartsm-1.gif (http://www.abswebservices.net/Merchant2/merchant.mv?Screen=BASK&Store_Code=MILODON&Action=ADPR&Attributes=Yes&Product_Code=18465&Quantity=1)Windage Tray
32250 https://static1.pt-content.com/images/pt/2005/11/addtocartsm-1.gif (http://www.abswebservices.net/Merchant2/merchant.mv?Screen=BASK&Store_Code=MILODON&Action=ADPR&Attributes=Yes&Product_Code=32250&Quantity=1)
(http://www.milodon.com/store/frmiddle.htm)or
32100 https://static1.pt-content.com/images/pt/2005/11/addtocartsm-1.gif (http://www.abswebservices.net/Merchant2/merchant.mv?Screen=BASK&Store_Code=MILODON&Action=ADPR&Attributes=Yes&Product_Code=32100&Quantity=1)
Windage Tray Install Kit81150 https://static1.pt-content.com/images/pt/2005/11/addtocartsm-1.gif (http://www.abswebservices.net/Merchant2/merchant.mv?Screen=BASK&Store_Code=MILODON&Action=ADPR&Attributes=Yes&Product_Code=81150&Quantity=1)Rear Pan Baffle32500 https://static1.pt-content.com/images/pt/2005/11/addtocartsm-1.gif (http://www.abswebservices.net/Merchant2/merchant.mv?Screen=BASK&Store_Code=MILODON&Action=ADPR&Attributes=Yes&Product_Code=32500&Quantity=1)Oil Pan gasket40100 https://static1.pt-content.com/images/pt/2005/11/addtocartsm-1.gif (http://www.abswebservices.net/Merchant2/merchant.mv?Screen=BASK&Store_Code=MILODON&Action=ADPR&Attributes=Yes&Product_Code=40100&Quantity=1)
All Milodon Small Block Chevy Pans Require the 1977-79 Thick Front Seal. Contained in Milodon's "Crush-proof" Pan Gasket Set #40100 Pick-Up to Pan Bottom Clearance MUST Be
Check and Adjusted from 1/4" to 3/8".
ItsA68
03-08-2006, 07:27 PM
CarlC,
Is the 8" deep pan lower than your headers? My stock pan is only 7" deep, and I'm worried about the extra 1" hanging down. I really want everything to be above the level of the subframe rails if possible. ledfoot, so it fits your 3.75" stroke OK? Windage tray OK with the long stroke?
~~fred
CarlC
03-09-2006, 08:09 PM
The pan does not hang below the headers or frame. There's a picture on my website that shows the assembled engine and headers. The site has been busy lately so it may be offline occasoinally.
