Handy Man
06-18-2015, 05:25 PM
Howdy,
I'm tuning the Quick Fuel 750 DP on my freshly built 347. After initially setting float levels and idle screws (highest vacuum at 1/2 turn from bottom) my AFR's were:
Idle: 13.5-14.5
Cruze: 12.5-13.5
Light Acceleration: 11-12
Anything over medium acceleration: Maxed out rich (gauge reads as low as 10)
It ran perfectly on the primary circuit, but getting into the secondary side too early caused a bog (not surprising with how rich it was)
So I upped the idle air bleeds by 2 sizes (from 71 to 73) to try to get the idle screws in the 1-2 range, reduced the secondary jets by 3 sizes (from 80 to 77) and reduced the secondary squirter by 2 sizes (from 31 to 25). After re-tuning my idle screws (3/4 turn from bottom now) my AFR's were:
Idle: 13-14
Cruise: 13-13.5
Medium to full throttle: 10-11
It still bogs if I get on it hard and fast, but not quite as bad. Still runs great on the primary side.
So what should I try next? I want to get light, medium and hard acceleration all around 13 so I'm thinking I should go with smaller primary jets, and maybe play with the secondary linkage and cam to try to reduce the bog?
Idle: 13.5-14.5
Cruze: 12.5-13.5
Idle: 13-14
Cruise: 13-13.5
