View Full Version : 69 camaro Eastwood fender rolling tool
mean buzzen half dozen
06-06-2015, 07:33 PM
Hey guys,
I bought an Eastwood fender rolling tool to roll the quarter panel lip on the rear of my 69 Camaro.
http://www.eastwood.com/ew-fender-roller-w-instruction.html
Before I try it out, I was wondering if you guys have used this tool on a 69 Camaro & if you guys have any tips/tricks I should do or look out for before I use it?
Does this tool work good for a 69 Camaro?
Thank you
ccmc
06-07-2015, 07:36 AM
It works well. Take your time and roll a little bit at a time. Use a heat gun to soften the paint or it will crack!
You also have to do the top separately from the curves as you will have to adjust the settings on the roller since our openings are not a curve.
06-07-2015, 09:46 AM
Thanks ccmc.
I was just wondering since the metal is double walled if the tool is strong enough to bend the metal & not have to cut anything.
ccmc
06-20-2015, 08:12 AM
I had a slight rub and used the roller successfully, it just takes time and do just a little pressure at a time.
Rick
06-20-2015, 10:42 AM
Great!
Thank you.
