View Full Version : Auto trans wont shift after ls1 install
CamaroJesse
06-06-2015, 01:25 PM
My dad just finished an LQ9/4l80 swap in his 68 camaro. The car runs and drives but the trans will not shift out of first gear. codes that are coming up are
p0713c-trans fluid temp
p0758c-2 to 3 shift solenoid circuit
p1638c-generator f terminal circuit
p18110c-trans fluid pressure position
any ideas on what could be causing these codes and lack of shifting?
thanks
jesse
csouth
06-06-2015, 04:12 PM
Well I can tell you that the shift solenoid code will cause problems with shifting. Had the code on the 4L65E in my old Yukon and it would not change gears. I believe it helps read the engine RPM and tells the trans when to change gears.
mean buzzen half dozen
06-06-2015, 08:02 PM
Off topic, but what trans cross member did you guys use for the 4L80E?
My friend that rebuilds transmissions told me it's always a good idea to change out the shifting solenoid pack & install a new one.
Does not cost much.
cpd004
06-07-2015, 05:19 AM
What ECM/TCM are you running?
CamaroJesse
06-07-2015, 07:26 AM
ecm is from texas speed.
cpd004
06-07-2015, 08:42 AM
Did you mention this issue to Texas Speed? Could be a programming issue.
